Test the gauges on 1956 to 1983 Ford Products. Works with Fuel, Temperature and Oil Pressure Gauges. Also verifies that the Instrument Voltage Regulator is working. Check each gauge at High, Medium and Low readings. Simply unplug the sender and attach the Tester with the supplied alligator clip leads, turn the ignition on, and verify the function of your gauges.
https://desertclassicparts.com/product/gauge-tester-gt-ford-1/
Last edited by AZ SuperVan on Sat Mar 13, 2021 9:56 am; edited 1 time in total (Reason for editing : lernt ta spel)
