When I got the truck, the heater assembly was in a cardboard box, and now I'm reconstructing it. I have a new motor (Four Seasons 35563), and core checks good, but need to figure out the switch wiring, especially the resistor (s?).
I see a switch on the front, seems to have three setting, assuming Off, Low and High. Three wires off the back, Green (power in), Red and Black. Also, only one resistor coil in the box of parts, the cardboard mount is long gone. So, I'm assuming that there's only one resistor coil, used for Low. Also, no ground wire seen, assuming the heater grounds through the mounting studs.
Does that all sound right?
Thanks much.
Thanks much.
