    1966 A100 Heater
    1966 A100 Heater Empty 1966 A100 Heater
    Post by Guest Mon Sep 29, 2008 10:47 am
    I need an A100 heater assembly. Anyone got one for sale???? Or just the silver tube with the temp adjusting valve.
    1966 A100 Heater Empty Re: 1966 A100 Heater
    Post by Guest Mon Sep 29, 2008 10:48 am
    I also need the rod that goes from the thumb button on the drivers door to the inside latch.
    Post by Guest Mon Sep 29, 2008 12:14 pm
    Try soaking your heater valve in PB Blaster..that should loosen it up.
    Post by Guest Mon Sep 29, 2008 3:05 pm
    The silver tube with the heater valve is rotted off.
    Post by Guest Mon Sep 29, 2008 6:18 pm
    If I ever get my parts van home, I'll have one for ya. Hopefully in the next couple of weeks, but maybe you can't wait that long, I dont't know.
    oo3
    Number of posts : 290
    Post by oo3 Mon Sep 29, 2008 6:37 pm
    i think i have the same problem as sarge - another one on my list of things to do - oo3
    Post by Guest Mon Sep 29, 2008 7:16 pm
    I have 2 possible parts vans. I just need to see which one I can get to 1st. I appreciate the info from everyone. I'll let you guys know whats happening. Also just an FYI the seats from a Chevy Astro or GMC Safari conversion vans fit the A100's great. Just a little modification the the under sides of the front captain chairs and the removal of the armrests and they go in very easily. The center captain chairs have a plate that bolts down to install them and the rear bench/bed you just need to make your own hold down brackets. It was a piece of cake to put the interior in.
    oo3
    Post by oo3 Wed Oct 01, 2008 5:47 pm
    ok i did a little work today removed heat assm - confirmed same problem as sarge, both ends of tube corroded and valve stuck - is there a generic valve that could replace this? - i suppose you could work around the tube part - oo3
    Post by Guest Thu Oct 02, 2008 3:10 am
    Stant makes a universal type cable operated heater valve. I guess you could make it work.
    Brian Bowie may have some good used ones.
    Post by Guest Wed Oct 08, 2008 6:41 pm
    Unfortunately I can't help you with the heater parts, sorry.
      Current date/time is Fri Apr 19, 2024 1:48 am
