    Rear Disc Brake Upgrade issue?
    Number of posts : 946
    Rear Disc Brake Upgrade issue? Empty Rear Disc Brake Upgrade issue?
    Post by BvrWally Sun May 24, 2009 6:39 pm
    OK...today I tried to assemble my parts for the New Upgrade to rear Disc brakes. The passenger side assembled with no problems, but was a bit tight. I then tried to assemble the driver's side, and there was NO way it would fit, as it was way too tight! I measure the rotor thickness at @ 1" and a shade under 1/16th inch? Maybe I should check for different thicknesses of pads??? I ordered the calipers from CPP out of Cali and they are for a 85 Caddy! Rotors from NAPA are listed for a 85 Caddy as well???
    Any ideas anyone??
    Rear Disc Brake Upgrade issue? RearDiscConversion24May2009001
    Rear Disc Brake Upgrade issue? RearDiscConversion24May2009002
    As you can see...there is absolutely no clearance when I try to load the rotor??
    B.W.
    Rear Disc Brake Upgrade issue? Empty Re: Rear Disc Brake Upgrade issue?
    Post by Digz Sun May 24, 2009 7:12 pm
    Okay, the firebird rotors are almost exactly an inch thick.
    Is the small nub on the caliper side pad riding out of the notches on the piston? That looks alot tighter than what I have going, Wish I had a part number for the pads the kit is using, Its got to be a difference in pads all the other dimensions are fixed in iron.
    Post by BvrWally Sun May 24, 2009 7:45 pm
    Can you explain?
    B.W.
    Post by Digz Sun May 24, 2009 8:05 pm
    Im wishing I had a picture of it now. towards the outside of the rotor on the metal part of the pad there is a small nub that seats into notches on the caliper piston, I'm just going by what was on mine and in noway am I speaking as an expert. scratch it will tip the padout at the top about a 16th or more of an inch. I have assumed and I may be wrong, that this keeps the caliper piston from turning as the E-brake functions. BTW it is recommended to use the E brake regularly to keep the caliper in adjustment.
    and it must be used to get the caliper in position before you bleed the brakes.
    if there are notches in the caliper piston it should have the nub on the inner pad. My pads were loose enough that Im hoping the piston clocks itself into place when I adjust becaus I couldnt get it to line up easily. If we need some pics I can disassemble it and take some.
    Okay I went back to one of Dons posts and swiped this pic, notice the notches in the piston.
    Rear Disc Brake Upgrade issue? Repair10
    Post by BvrWally Sun May 24, 2009 8:14 pm
    OK...I know what you mean now! Thanks!
    B.W.
    Number of posts : 987
    Post by RipVanArkie Sun May 24, 2009 8:25 pm
    Try backing off the ebrake manually, that could be the problem.
    B.W., sorry I was out of pocket all day and of little help.
    Later,
    Rip
    Post by donivan65 Sun May 24, 2009 8:56 pm
    If you don't find anything,,,,,I have run into too thick pads on a few vehicles,,,,,they would not work no how,,,,,,take your pads to some other auto parts store,,,,compare or measure the thickness,,,,,,,you might find some brands that are thinner,,,,,,
    Post by BvrWally Mon May 25, 2009 2:43 am
    Thanks Don...I was thinking about doing just that!!
    B.W.
    Post by donivan65 Mon May 25, 2009 8:02 am
    Those pads look pretty thick,,,,,but like the guys just said,,,,3 things can be affecting the position of the pads, the park brake arm, the worm gear and the ratchet,,,,take off that arm, crank in the worm gear and then, without the bottomed out worm gear turning, ratchet the notch into the right pad position,,,,,
    Number of posts : 7900
    Post by DanTheVanMan Mon May 25, 2009 8:11 am
    Yeah, did a dry fit on mine with the caddy plates and the 15" centerline's. and it's going to be reel close, maybe too close!!
    Rear Disc Brake Upgrade issue? Qr_cod10
    Post by BvrWally Wed May 27, 2009 4:03 am
    Dan I know what you mean about "Close"! I even placed a 3/16th spacer on the rotor and it still just touches the caliper! I will switch to a 1/4" one I just ordered from CPP, that should take care of that??
    Rear Disc Brake Upgrade issue? RearDiscConversion24May2009003
    B.W.
    Post by donivan65 Fri May 29, 2009 3:25 pm
    You might be able to move the caliper closer to the rotor by adjusting the mounting holes,,,,,so the question is, how close is the calipe to the rotor on top and the center,,,,,,,any room to move the caliper down and away from the rim?????
    Post by DanTheVanMan Fri May 29, 2009 6:15 pm
    Thinking the spacer idea will work but if not I would have to turn down the rotors as well to adjust the calipers. Not enough space in there.
    Post by Digz Fri May 29, 2009 7:11 pm
    Whats hitting on the centerlines Dan? what part of the wheel I mean, I had to put 1/2 inch on the Keystones to clear ,but they had that wide tire relief in the outer steel rim, I would have thought the centerlines would be a smooth rim into the lug flange area?
    I have 2 pairs of 5/16" spacers if anybody needs them, multi lug pattern. Also wondering what B.W found as the cure for tight rotors?
    Post by DanTheVanMan Fri May 29, 2009 7:21 pm
    They are smooth. The calipers just hit the wheel when I tighten the lugs. I took BvrWally's advice and ordered some 1/4" spacers. Pretty sure that will do it. But if not I will turn down the rotors 1/4" and re-adjust the caliper's like Don suggested.
    Post by donivan65 Fri May 29, 2009 9:33 pm
    Well there are a lot a variables to consider if the wheel hits the caliper. One is to move the caliper in closer to the rotor even making the rotor smaller if possible. Then there is to move the wheel away from the rotor with spacers or use different wheels,,,,,so lets see what problems are and what the solutions are,,,,,,
      Current date/time is Wed May 01, 2024 8:46 pm
