    Brake Dual Master Cylinder Upgrade Problem
    Skapbil
    Skapbil
    Number of posts : 21
    Registration date : 2016-01-29
    Brake Dual Master Cylinder Upgrade Problem Empty Brake Dual Master Cylinder Upgrade Problem
    Post by Skapbil Tue Nov 02, 2021 6:18 am
    Working on the dual MC upgrade to my 65 (Thanks to donivan65).  While at it, replaced the front and rear bushings on the 1st/Reverse and 2nd/3rd transmission linkage rods.
    Used a NAPA M1880 MC, GM bushings #3975132 at the steering column, and GM bushings # 3975131 at the tranny shift levers.  Shifting is smooth and tight – no slop.
    Here is where I am a bit stumped.  The 1st/Reverse linkage rod is rubbing the top of the MC when in neutral and shifting from 1st to Reverse.  Hate to end up with a hole someday.  Is there a fix for this?
    Brake Dual Master Cylinder Upgrade Problem Shift_10
    Buddyr likes this post
    Skapbil
    Skapbil
    Brake Dual Master Cylinder Upgrade Problem Empty Re: Brake Dual Master Cylinder Upgrade Problem
    Post by Skapbil Fri Nov 05, 2021 5:55 am
    Has anyone else experienced the transmission linkage rod hitting the top of the MC when putting a 2nd Gen MC in a 1st Gen?
    Number of posts : 2626
    Post by savage Fri Nov 05, 2021 6:38 am
    On my 1st gens its a Major pain to get the caps off brake Master with the shift rods on ether side(3 on tree).
    66BC
    66BC
    Number of posts : 159
    Post by 66BC Fri Nov 12, 2021 6:38 am
    Make sure the rods are also running through the proper u channels towards the back. Factory had rubber moldings on those u channels as well so it’s a smooth shift and stay in a certain route towards the front. Mark Burnitzki (108VanGuy)sells them. He can be found on Facebook or his parts website (https://vintagechevyvanparts.com/)
    savage likes this post
      Current date/time is Wed May 08, 2024 2:00 pm
