I took my a108 to a tranny shop to replace the pan, oil, filter, gasket, which they did. I'd have to work on the street and that's a no bueno. They found the kickdown linkage was not hooked up. A bracket was missing. I got the Lokar cable and bracket to upgrade the system. they said they could install it. They've had the thing since Wednesday morning at 8 and it's now Saturday. They say it's going to be ready later today around noon. Originally, it was supposed to be next day. They said 2-4 hours of work. Depending on if they have to do the accelerator cable with it.
How long does it take to install the kickdown linkage cable and calibrate it properly?
I'm also thinking, since the kickdown was not working, it was burning out my transmission. Should I just spend my money on a remanufactured 727? Any recommended source for a reman?
I figured, even if I have to replace the trans, I still need the kickdown linkage cable set up, so it's worthwhile.
I kind of hate transmission shops. It's a racket.
