While searching the web, I have seen some postings related to this /6 to 318 V8 swap. I am hoping to consolidate things...and I seriously need the help!
In my 1965 A100 Van, I'm going to an '85 318 V8 w/a 904 auto trans, from a /6 3-on-the-tree...I THINK.
If I could find the proper bell housing and related parts to keep my 3 speed manual trans, I might stick with the 3-on-the-tree, but it just seems that going to an automatic trans would make driving life much easier (particularly for towing a camper...see pic attached, if I attached it properly that is). Any thoughts on this: appreciated.
I need the frame brackets and engine brackets for the V8 motor mounts.
I need the trans mounting/support bracketry - whatever it is, as I expect it is markedly different from the manual 3 speed.
I've dropped the drive shaft for towing, but never even fiddled with the trans yoke/plate the drive shaft mounts to in the 3 speed manual trans - so if I need a different mounting yoke at the 904 trans tail to use my stock drive shaft, please advise.
I really appreciate all the help/advice I can get guys. Thank you! Steve
