I need to re-weatherstrip at the least the rear doors. Possibly others. Using the search I found that I could get that at restoration specialties.
There is an electrical issue I need to track down. Perhaps someone could help. The brake light is always on and when I hit the brakes the right side parking light comes on. (I havnt looked into this at all. Havnt even checked brake fluid but did drive it home with no problems)
I want to insulate it. Looking through old posts I found many different opinions on this. I would like to do it but dont want the van to rust which is the main reason I found not to do it. I read that not putting the insulation against the metal will prevent this from happening. If thats true then thats what I will do.
My van has the 250 L6 with the powerglide. For cruising on the highway I at least want to swap the powerglide. I havent decided if I want to pull the engine. I found a lot of info on tranny swaps from the three speed manual to an auto but not much on a powerglide to newer auto swap. Is it just a bolt in swap? I was also reading that the best mileage can be had out of a V8. Because I have a friend with a TBI 4.3L V6 I was thinking I might put that in with a 700R4 behind it. What are opinions on that?
I will also have to fix a spring shackle on the drivers side. I have never done anything like that before so any info would be helpfull. Also along with that I was thinking I might want to replace some of the steering components in the front. Its a bit more loosey-goosey than I would like if I am going to be driving for long periods at a time.
I also have bought the... I think its M1D1? Disc brake bracket set. So that I can convert to discs on the front.
Most of this stuff I have not done before but I am always into learning more. I have already done an engine swap before so I know I have at least some skills. As I said I am very open to suggestions as to what to do. I dont have a specific destination so I dont plan on going anywhere fast but I want decent mileage out of it and the ability to drive on the freeway. Thanks in advance.
