+9
FIZGIG
Oscarm
Econolove
CraigK
thecruger
13 posters
    Almost ready for the road !!!
    thecruger
    thecruger
    Number of posts : 205
    Registration date : 2008-11-27
    Almost ready for the road !!! Empty Almost ready for the road !!!
    Post by thecruger Sun May 03, 2015 8:32 am
    Well after 3 or 4 weeks of working hard to get the Econo going she crawled out of the garage under her own power,
    I rebuilt the carb, new exhaust manifold gasket, new flange gasket, rebuilt the master cylinder, went over all the brakes, replaced the rear rubber brake hose, replaced brake line from proportioning valve to rear and rewired all the lights so it has turn signals and brake lights again .....  cheers
    here she is basking in the sunlight after who knows how long..
    that ugly ass roof vent is coming off today..
    was at the Canfeild swap meet yesterday and found a brand new in the box 15 x 30 sunroof to fill that ugly hole upfront ... got it for $60 so I am happy... Very Happy
    So the work goes on....but its getting closer...
    Almost ready for the road !!! Van-2_zpscg6vvhme
    Almost ready for the road !!! Van-1_zpsmqkd8l3t
    Almost ready for the road !!! Van-3_zpsxvb9pamo
    Almost ready for the road !!! Van-4_zpsh6aberbu
    Almost ready for the road !!! Van-5_zpsd7nta9mj
    Almost ready for the road !!! Empty Re: Almost ready for the road !!!
    Post by Big W Sun May 03, 2015 12:03 pm
    Damn that looks nice and clean. Great job on getting her ready. Looking forward to seeing the roof vent installed. cheers
    Number of posts : 2086
    Post by Seth G Mon May 04, 2015 10:23 pm
    Nice looking van once you ditch the vent. Congratulations!
    CraigK
    CraigK
    Number of posts : 141
    Post by CraigK Tue May 05, 2015 3:55 am
    Looks awesome. Nice job.
    Number of posts : 1422
    Post by Magic Bus Wed May 06, 2015 7:35 pm
    Looking great, sure feels good to make progress and drive it around!
    Post by Seth G Wed May 06, 2015 8:00 pm
    Take some pictures of the sunroof install Smile
    thecruger
    thecruger
    Post by thecruger Sun May 10, 2015 1:54 pm
    been working on the old van some more... have yet to decide the sunroof install,
    started making a new gauge cluster for it since none of the gauges work anyways.
    Almost ready for the road !!! Dash1_zpsmtnidzkd
    some of the new gauges,
    Almost ready for the road !!! Gauges_zpsojomvift
    ordered new Fuel gauge for ford with the 73 - 10 ohm rating same as the van so original sending unit should work fine.
    Almost ready for the road !!! Fuel-gauge_zpsnn0yoygw
    and new speedo
    Almost ready for the road !!! Speedo_zpskyvhkcnh
    so we shall see...  I can't wait.
    Econolove
    Econolove
    Number of posts : 43
    Registration date : 2014-10-13
    Post by Econolove Sun May 10, 2015 2:07 pm
    Ive been wanting to make a new gauge cluster as well. Looking forward to seeing how yours turns out. What are you planning on using to cut out the gauge holes?
    Oscarm
    Oscarm
    Number of posts : 91
    Registration date : 2014-05-06
    Post by Oscarm Sun May 10, 2015 2:23 pm
    Just finished a full-fleet of 'Equus' gauges too. Liked the neat mounting system. Since your not using an ammeter, try wiring all your instruments up through a 12 pin radio connector. Then you can simply 'unplug' the entire instrument pod in a few seconds for behind-the-dash access. Of course, you still need to uncouple the speedometer cable, unless that's an electronic speedo....I used the original instrument panel, since I wanted to keep the old speedo (nostalgia). Your method is better.
    I used a 2" hole saw for the gauges, but backed it up with a piece of scrap plywood so it
    didn't rocket off into my shop wall.
    If you want some pix of the wiring, email me: 'melaqueoscar(at)gmail.com'
    Haven't figured out the pic-post complexities with this site.
    thecruger
    thecruger
    Post by thecruger Sun May 10, 2015 7:09 pm
    There is a machine shop around the corner from me that will cut it all out and clean the edges for about $10.
    I have a 2" hole saw but I would rather the shop do it..., they will check and make sure everything is centered before they cut it.
    Hey Oscarm I would like to see the finished product if you figure out how to post pics..
    FIZGIG
    FIZGIG
    Number of posts : 334
    Post by FIZGIG Fri May 15, 2015 11:59 am
    Nice van!!! I wanna change all my gauges too. What are the best ones to go with?
    thecruger
    thecruger
    Post by thecruger Fri May 15, 2015 6:01 pm
    I went wit the Equus 8000 series , will let you know how they work when I get them installed,
    still waiting for my fuel Gauge to show up, have to make sure you order the ford one with 73 - 10 ohm so the stock sender should work fine.
    Also order a nice shiny piece of 1/4" thick Black acrylic , thicker than the aluminum I got and I wont have to paint it.
    Post by Seth G Fri May 15, 2015 10:30 pm
    I've been looking at those equus gauges to. So it will be good to hear they work out for you guys
    thecruger
    thecruger
    Post by thecruger Tue Jun 02, 2015 12:07 pm
    UPDATE... finally got my acrylic Plexiglas,
    here is 67 instrument cluster and the 2015 cluster..
    Almost ready for the road !!! 6ac9912a-514c-4aa5-8ae0-8ed832d09136_zpsyekwu3ka
    Post by Big W Tue Jun 02, 2015 8:30 pm
    looks great. cheers
    Number of posts : 176
    Post by wirepuller Tue Jun 02, 2015 8:45 pm
    Great work on the gauge cluster!!
    Gauges look awesome!
    WP
    RF Man
    RF Man
    Number of posts : 120
    Post by RF Man Wed Jun 03, 2015 3:47 am
    Looks Great---I'm getting ready to do the same thing. Do the Equus gauges use the stock sending units?. Do they have metal frame rings?. Still trying to decide what brand to use.Thanks Mike
    thecruger
    thecruger
    Post by thecruger Wed Jun 03, 2015 2:22 pm
    If you get the fuel Gauge for Ford / Chrysler you can use the stock sending unit, (73 - 10 ohms)
    rings are plastic.
    thecruger
    thecruger
    Post by thecruger Wed Jun 03, 2015 4:20 pm
    Well spent all day installing, wiring.. so on.. got it installed, everything is working except the fuel gauge..
    going to run new wire from sender to Gauge and make sure sender is grounded good before I yank the sender out..
    also started to build a console in front of dog house for cup holders and stuff, plus it made it easy to run the temp sensor and oil pressure Gauge line.
    Almost ready for the road !!! Cbfb41dc-fca4-4c72-9eeb-c0b92427a8b6_zpsfgjpshvt
    Almost ready for the road !!! F32d4224-2c2f-49a4-b3fc-fa178f435205_zpsuaq8nirb
    Almost ready for the road !!! Fab73dd8-aa9a-4bc0-90cd-0c625df366d7_zps72h9bvns
    Almost ready for the road !!! Bdcc9c57-792a-4731-bcca-d04c4bbaf8a0_zpssztf5sfh
    Post by Seth G Wed Jun 03, 2015 5:06 pm
    That turned out real nice! cheers
    Number of posts : 394
    Post by dan nachel Wed Jun 03, 2015 5:36 pm
    I read somewhere that aftermarket fuel guages don't work with the ford sender. The one I installed only works about 10% of the time.
    thecruger
    thecruger
    Post by thecruger Sat Jun 06, 2015 5:50 pm
    Drove it for the first time today, everything worked Great..
    fuel Gauge still not working going to order a new sending unit and be done with it I hope..
    installed the new roof vents and sealed them,(Double Bubbles), ... guess I'm going to have to start planning the interior next..
    Almost ready for the road !!! Van-6_zps4pthyxvz
    Almost ready for the road !!! Van-7_zpsntfhr8j1
    Number of posts : 809
    Post by Bruce67Econoline Sun Jun 07, 2015 5:53 am
    Nothing like that first ride, Congrats. Enjoy your van my friend.
    Post by Big W Sun Jun 07, 2015 3:33 pm
    Your vans looks real sharp. Happy to here your first ride went well. cheers
    Post by vanny Sun Jun 07, 2015 7:09 pm
    Glad it went well for you Cruger!!! Enjoy the fruits of your labor! Love those Gauges!!!
      Current date/time is Mon May 13, 2024 11:58 am
