Hey guys I got my van home and it seemed to be running fine Sunday but Monday it would not start sounded like the battery was dieing so last night i bought a new battery and tried it and it fired right up! this morning i went out to drive it to work and it would not start like the battery was dead any ideas?
Starting issues
Re: Starting issues
The simple test would be to turn the headlights on,,,,,,,,if they don't come on,,,,,,you probably got a drain on the system, and the battery ran down,,,,,,,,if the headlights stay bright when you try and start the engine,,,,,,,you have a starter problem,,,,,,,but best test is to put a voltmeter on the battery and see what the voltage is and does when you try and start it ,,,,,,,,
Re: Starting issues
I just had the same problem and my alternator was bad.
Re: Starting issues
charge the battery, then start the engine. while engine is running, remove the negative cable from the battery. If the engine dies, you have a charging problem, either your alternator or wiring is at fault.
Re: Starting issues
i found the issue last Friday it was a ground wire that was touching the body sucking the juice out of the battery! she fires up now.
but yesterday i started her up and the GEN light is on now. i have a bunch of little things to work out of it but slowly it will come together!
Re: Starting issues
Cool. Way to go on finding the problem
Re: Starting issues
Well, a ground wire is supposed to touch the body,,,,,,if you have a voltmeter, you can see if the system is charging,,,,,,,that light being on means the alternator is not charging,,,,or the regulator or wiring is bad.......
Re: Starting issues
A good way to check if the alernator is working is to tuch the rear bearing with a screwdriver. If it is charging there will be a magnetic draw on the metal screwdriver. Works with all alternators!
Re: Starting issues
got this handled new alt and voltage reg and a new battery. now it isn't charging for some reason. i need to check the wiring.
