+7
Rick's 66 Chevy Van
AzDon
kookykrispy
BAS0301
11 posters
    wheels - Backspace
    BAS0301
    BAS0301
    Number of posts : 14
    Registration date : 2014-06-05
    wheels - Backspace Empty wheels - Backspace
    Post by BAS0301 Fri Nov 13, 2015 11:47 am
    Whats the best source for information on tires/wheels/backspace for a '67 G10?
    kookykrispy
    kookykrispy
    Number of posts : 1533
    wheels - Backspace Empty Re: wheels - Backspace
    Post by kookykrispy Sat Nov 14, 2015 12:10 am
    probably other 1st & 2nd gen van owners.
    Welcome to the forum. may I suggest editing your profile and listing your city? Washington is a big place. Actually it is two places. lol
    You could have several vanners right near you, but if you don't list your city, we'll never know???
    Post by vanny Sat Nov 14, 2015 4:38 am
    If you click on the search tab at the top of the page and type wheels, you'll see many threads on the subject. Like this one. https://vintage-vans.forumotion.com/t4501-wheels-on-66?highlight=wheels
    AzDon
    AzDon
    Number of posts : 742
    Post by AzDon Sat Dec 05, 2015 8:28 pm
    Most of the wheels that look right on these vans are classic 70's style offsets.... generally 50% or more (usually 62-63%) is to the OUTSIDE of the mounting face resulting in a Deep-dish wheel and a widened stance...... Wheels with modern offsets (deep on the back side) are unlikely to look good
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Number of posts : 331
    Post by Rick's 66 Chevy Van Sun Dec 06, 2015 2:10 pm
    good ? so if we would want too put a set of crager ss on a 1965 chevy panel van what would we ask for on front and then on back and what size tires?
    Number of posts : 1388
    Post by wideload Sun Dec 06, 2015 3:58 pm
    Rick without messing with the suspension about the largest you can run on the front of a 1st gen would be a 15"x 7" standard offset with a 235-60 tire. That's what's on the front of my 65 with a V8 and I don't have any problems. I'm running 15"x 8" standard off set on the rear with the same tire.
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Post by Rick's 66 Chevy Van Sun Dec 06, 2015 4:44 pm
    ok that sounds good Kev
    Post by Twinpilot001 Mon Dec 07, 2015 7:50 am
    just off the top of my old memory??????????? affraid seems all backspacing was a standard 3 & 1/2 " in the 60-70 area.
    Number of posts : 1293
    Post by Lazarusvan Mon Dec 07, 2015 6:01 pm
    wideload wrote:Rick without messing with the suspension about the largest you can run on the front of a 1st gen would be a 15"x 7" standard offset with a 235-60 tire. That's what's on the front of my 65 with a V8 and I don't have any problems.  I'm running 15"x 8" standard off set on the rear with the same tire.
    I hope that's not 100% because I'm planning to use 15x8's on all 4. I think my backspacing is under 4". Seems M1D said that would work even with front disk setup unless I misunderstood.
    If not, I'm gonna be banging something to make room.
    Post by wideload Mon Dec 07, 2015 10:06 pm
    Laz not 100% but I tried 8's on the front of mine and they would barely rub the front lower corner of the wheel well. M1 knows more about this than probably anyone else here so if he says they will work I would trust him.
    Post by Lazarusvan Tue Dec 08, 2015 7:37 am
    WL,
    The current late 70's Vette wheels currently on the van I was told could just slightly rub under hard cornering/acceleration with the disk setup. Looking for as much meat and height on the tires as possible. Hoping some room can be made....
    Post by wideload Tue Dec 08, 2015 8:53 am
    Laz check out Billski's sport van. I pretty sure his lower front wheel wells have been modified for tire clearance. I'm pretty sure he's running bigger tires than I am.
    wheels - Backspace 100_1610
    Post by Lazarusvan Tue Dec 08, 2015 11:05 am
    wideload wrote:Laz check out Billski's sport van. I pretty sure his lower front wheel wells have been modified for tire clearance. I'm pretty sure he's running bigger tires than I am.
    Thanks.
    I had heard he recently added bigger tires or wheels?
    It looks like they sit outside the wells a slight bit which is fine with me.
    As long as a hammer can fix the clearance issues, I'm straight!
    If I could figure out what size BFG's to get that will work, I'd be even straighter!
    Appreciate all the great help here.
    Post by wideload Tue Dec 08, 2015 3:20 pm
    Here's a different shot, better shows how far they stick out.
    wheels - Backspace 100_1611
    Send Billski a PM, it might take him a while but he'll answer you.
    Post by Digz Tue Dec 08, 2015 3:40 pm
    Don't quote me but I think Billski is running 15x8s with 245/60s all round. They look tough !
    Post by wideload Tue Dec 08, 2015 4:24 pm
    I think your right Joe. I knew they were bigger than my 235's.
    Post by Lazarusvan Tue Dec 08, 2015 8:07 pm
    So, here is what I have with existing wheels that are being replaced and 225/60/15's.  This is with the wheel fully turned.  I was advised that this would be really close and might rub.
    We were thinking that I would need to drop down to a 215 tire in order to make this not rub that front side wheel edge while using an 8" wide wheel and 15" tire.  The only other solution would be to cut the well out about an inch, which I wasn't real sure I wanted to do but his van looks great.  I missed the part on first read about Bills's front wells being modified a bit.  That would make sense. That area just got new sheet metal and if I'm ever going to trim it, this would be the time before it goes into paint.
    If mine is this close and might rub, Bill's well must have been cut down.  Also curious if using a 215 up front and 225 in the rear would be enough size change to make that ass end look a bit beefier if I don't do any cutting and go down in size up front. No plans for 10" rears.
    And those are some mean looking tires filling up that space.
    wheels - Backspace _57_210[/url
    wheels - Backspace _5712
    Post by wideload Wed Dec 09, 2015 6:10 am
    Laz if your not concerned with being able to rotate the tires for wear purposes you could look at a 50 series rather than a 60 series. Would be the same width just shorter side walls.
    Post by Lazarusvan Wed Dec 09, 2015 9:56 am
    Thanks, Mike. I really want the largest possible tire all around without them sticking out more than a tad. I like Bills big tires but might extend out a bit more than I prefer.
    End of day, I probably want to fill the height of the tire more than anything while still using the 8" wide wheels since I'm at stock height and not flipping axles, etc. I have air shocks in the rear so I can play with that on the upward end if I need or want to.
    Number of posts : 672
    Post by samsvan Thu Dec 10, 2015 5:17 pm
    Lee, I saw this in the members gallery. Something to go by?
    Happy B-day, Sam
    https://vintage-vans.smugmug.com/Vans/Wheels-and-Tires/i-WRSrgNd/A
    Post by wideload Thu Dec 10, 2015 5:23 pm
    That's Donivan's 65.
    Post by Lazarusvan Fri Dec 11, 2015 7:24 pm
    Thanks, Sam. That is a nice little comparison. No low profiliers for me..beefy or nothing.
    I'm thinking I should trim those wheel wells for sure and then I can always stay with 15" wheels. I just don't want to pop out much beyond the van if I can help it. Always a trade off..
    Number of posts : 1686
    wheels - Backspace Empty DODGE / MOPAR
    Post by westcoastvanner Wed Apr 27, 2016 10:08 am
    I have a 1967 Dodge A100 what is the back spacing on the wheels?
    Post by Twinpilot001 Wed Apr 27, 2016 11:48 am
    most everything built -earlys were 3- 3&1/2 " backspaced!! When custom wheels were being built in the 60's we never worried about backspace! They were all the same except the racecars,dragsters, and roundy round cars! affraid
      Current date/time is Wed May 08, 2024 1:55 am
