I picked up a clean 66 A100 Sportsman: 34K miles, /6, 3 on the tree.
Since I purchased it I installed new 2.5" exhaust, new alt/reg, rear seat with 3pt belts, made a heatsink/heat shield for carb and insulated fuel lines, new fuel pump, tune up, lube, made a roof rack, F spring bushings, had the windows tinted.
Bought it with all new brakes, window seals, paint. For once I bought something decent to begin with so not much resto work required. I have plans for the interior, and have entertained the idea of a V8 swap. I sold some other stuff off so I could have a classic that is more family friendly. So far has been a lot of fun.
It runs good with the slant, and power is OK, it does the hills better then i thought it would (far better then a VW) I tow a small trailer with it, haul quite a bit of stuff in/on it. We use it for family outings, camping, ect. We already drove it to Maine coast, and many day trips all over NH and VT. I used it to commute the past couple of weeks while working on my DD, I have to say it got a bit old commuting 90 miles a day with it and it is nice to have my car fixed!
Eventually I would like to be able to haul a small boat with it (2K lb max) or perhaps a small car so a V8 and front disc brakes may be in the future. I like the slant though and may hop it up instead.
I have a few questions:
The A745 has a very tall first gear. After doing some research I see that there was a 2:55 (what i think i have) and also a 3.01 first gear for these transmissions. Anyone ever change ratio's? do all of these have this super tall first gear?
It has the ball and trunion front joint, do all years use this or did it change at some point?
Anyone know if I can get widened steelies that will accept the stock caps? Right now it has some very tall tires. Its nice to have some sidewall for the rough roads around here but I would not mind going a bit lower/wider.
I need to wait 7 days to post pics, but will do so ASAP
Have learned a lot from this site already, many thanks.
