My little 144 will only run with the choke out. Is this jets or floats problem? Thanx for any answers.
144 problem
econopoor- Econoline Guru
- Number of posts : 1747
Re: 144 problem
Sounds like a vacuum leak. Check the hoses and carb gasket. Are you going to make it to Petit Jean this year? It's almost here. Duane.
- Number of posts : 2086
Re: 144 problem
How long has it been like this? If there doesn't appear to be a vacuum leak(s) you likely need to rebuild the carb. Does it have an Autolite or a Holley carb? Mine was doing that and it turned out to be an improperly assembled carb and it was varnished up. It was missing a check ball and a weight on another check ball. The idle circuits are very tiny and can get gummed up if the carb has been sitting a long time.
