Hello,
I have a '63 Eco pickup with a carb? problem. Has a small Holley but not like the ones in the manuals. I can squirt a little gas in the carb & the engine will fire right up & run till the gas is gone. It has an electric fuel pump & a filter right at the carb. The pump pumps gas right to the carb. There is a fitting that the filter screws into & it seems that the gas does not go thru that fitting. Has a little plunger in it. I thought that my fuel pump was to strong so I bought one with less pressure. What is that fitting? Cannot find it on a parts picture. I guess that I haven't found the right carb pic? I am 1/2" from starting my Eco.
Thanx Much!
Brat
Thanx Much!
Brat
