Shit did I screw up my perfectly good day and engine block. Good day at work and had time to go into the garage and finally put the new motor and tranny with rebuilt clutch back in the van. woo Hoo! I was one happy camper until I managed to over torque a bolt a snapped a piece of the cast iron block right off. What the hell do I do to fix or have this repaired? I can not use the clutch with out this. Pressure is applied to this bolt everytime you press the clutch.
What i broke was the bolt hole where the clutch rod attaches. The lock nut was still loose on the bolt so I figured the bolt was not all the way in the block and snap! Pics to show the damage. Talk about turning a great day bad with one quick moment.
Do I try welding it back together or Tap into the block and add more threads? Any ideas would be appreciated.
