    Suspension question.
    ALABAMA ANDY
    ALABAMA ANDY
    Number of posts : 20
    Registration date : 2013-01-18
    Suspension question. Empty Suspension question.
    Post by ALABAMA ANDY Tue Jun 09, 2015 1:01 pm
    Hi everyone Very Happy
    Sorry ive not been on here for a while.....
    Just a quick question about my 69 A108.
    Since I bought her 2 or 3 years ago, most of the work ive been doing has been all on the inside.
    I decided to change the tyre size the other day to 1.....make the steering lighter & 2.....get the gearing down a bit.
    I had 225/75x15's on the front & 235/75x15's on the rear.
    HUGE balloons !!!!!
    I got pretty used to the van looking tall & fat.
    Anyway.....I've now got 195/70x15's on the front & 225/70x15's on the rear.
    It looks pretty low & obviously has a bit of nose down rake too now.
    A bit too low to be standard as it goes ?
    I know its had new springs, new bushes & new gas shocks before I bought it.
    So I had a look around & all four leaf springs look flat & the rear spring shackles look upside down to me (or should they be like that) ?
    Usually a leaf spring hangs below a shackle, but on my van its above.
    If its been flipped it would lower the van about 3 or 4" ?
    The front looks shock but again.....the springs are flat.
    Any ideas out there ?
    Its a 69 A108 Bus with a 318 / Auto by the way.
    Many thanks.
    Number of posts : 8729
    Suspension question. Empty Re: Suspension question.
    Post by dix Tue Jun 09, 2015 5:08 pm
    your rear springs should be above the shackles
    busman78
    busman78
    Number of posts : 483
    Post by busman78 Tue Jun 09, 2015 5:58 pm
    Like this, shackles up, axles will be centered, if you put the shackles down the axles will not be centered. I added a lift to my rear.
    Suspension question. Img_0110
    Post by dix Wed Jun 10, 2015 2:54 am
    nice rear end
    Post by vanny Wed Jun 10, 2015 9:32 am
    Disc brakes all around? Looks nice and neat under there, busman !!!
    busman78
    busman78
    Post by busman78 Wed Jun 10, 2015 10:15 am
    Yes, disk all the way around, thanks, only time it will look clean, once on the road the shine goes away.
    Number of posts : 3046
    Post by RodStRace Wed Jun 10, 2015 10:54 am
    I had a big response typed up and included pics, then it all went poof!
    Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
    So here's the short version;
    I measured 5 vehicles here (various engines, state of load and other variables) and the results are as follows:
    Measuring from the center of the upper shock bolt to the center of the lower shock bolt, the fronts are 17" (431.8 mm) plus or minus a half inch (13 mm).
    The rears are 19" (482.6 mm) plus or minus an inch (24.5 mm).
    I'd like to see others measure this to confirm, but they all fell within a pretty narrow margin. If you have new springs, that would be interesting too.
    ALABAMA ANDY
    ALABAMA ANDY
    Post by ALABAMA ANDY Wed Jun 10, 2015 5:22 pm
    Cool.
    Thanks for the response guys.
    Guess I just got so used to the huge tyres it now looks a lot lower.
    I will do the measurments RodStRace.
    New springs, bushes & shocks.
    So I guess is should be bang on.
    I'll Post up the answers on this thread.
      Current date/time is Sun Apr 28, 2024 5:44 am
