    rusted side door bottom
    steelrat
    steelrat
    Number of posts : 116
    Registration date : 2014-11-24
    rusted side door bottom Empty rusted side door bottom
    Post by steelrat Tue Dec 23, 2014 12:42 pm
    How do I best repair this? I do not have a welder, and am on a tight budget.
    Thanks.
    rusted side door bottom Img_2026
    rusted side door bottom Img_2028
    Number of posts : 2011
    rusted side door bottom Empty Re: rusted side door bottom
    Post by Barnabas Sat Dec 27, 2014 7:43 am
    While welding in new steel would be best, you could also fiberglass it. Basically small sheets of fiberglass cloth with a special glue. Put it on in layers, then sand it down when dry. should look like a Corvette when done.
    Number of posts : 1747
    Post by econopoor Sat Dec 27, 2014 9:54 am
    Unless you cut that out and weld in new metal the rust will never stop. A fiberglass repair is just temporary. Putting fiberglass over it will not stop the rust and the glass will just fall off eventually. If you don't have a way to weld new metal in you should replace the door with a good one. Or find someone close that can weld it for you.
    Number of posts : 326
    Post by jimthefred Sat Dec 27, 2014 1:44 pm
    No such thing a cheap and easy
    steelrat
    steelrat
    Post by steelrat Mon Jan 19, 2015 5:48 pm
    Does anyone have some pictures of how to repair the bottom of the door? Needing to know how to form/shape the bottom channel.
    Thanks,
    Shaun
    Post by econopoor Mon Jan 19, 2015 7:34 pm
    Kev's restoration.
    Spend a few hours reading this thread. Everything you ever wanted to know about patching rust is right here.
    steelrat
    steelrat
    Post by steelrat Mon Jan 19, 2015 8:07 pm
    Holy crap. What a resto. Good thing he is a fabricator/welder. Both of which are experience and skills I lack.
    Post by econopoor Mon Jan 19, 2015 8:23 pm
    He learned a lot about sheet metal as he went along. It's all basic stuff. It's metal. Just cut and weld till there's no more rust.
    plvmb
    plvmb
    Registration date : 2015-01-07
    Post by plvmb Tue Jan 20, 2015 4:18 am
    Put that red rust stopper primer for now until you find a better door or have that fixed correctly. John Los Angeles, CA
      Current date/time is Thu May 09, 2024 11:15 am
