steelrat
    Getting heat out of heater
    steelrat
    steelrat
    Number of posts : 116
    Registration date : 2014-11-24
    Getting heat out of heater Empty Getting heat out of heater
    Post by steelrat Sun Dec 14, 2014 2:37 pm
    I have been fiddling with the knobs and controls for the heater. I can get it to blow on high and low both defrost and floor, but cant get heat to come on. Thr temperature knob just seems to turn left and right easily but no change in temp. Any advice?
    Thanks
    Shaun
    Number of posts : 394
    Getting heat out of heater Empty Re: Getting heat out of heater
    Post by dan nachel Sun Dec 14, 2014 5:40 pm
    First, I would check to see if the hoses are conected to the heater. Then feel them to see if they are getting hot. If those two things check out, then I would pull the heater core and inspect the valve. Be carefull with the valve. They are not cheap and hard to find.
    Number of posts : 2011
    Post by Barnabas Sun Dec 14, 2014 6:14 pm
    The water valve might have rusted shut. Disconnect the hoses and look.
    Also the core may be clogged. Disconnect the hoses, connect a water hose from the house and see if you can get water to run through it.
    Carl
    Number of posts : 143
    Post by Carl Sun Dec 14, 2014 8:47 pm
    You say the temperature knob seems to turn left and right easily; yet to use the TEMP knob; you pull it out, not turn it. The valve under the van, that the temp cable goes to, likes to get stuck, as mine did. Now have new plastic replacement valve you can buy at Macs, or I got one at Napa.
    steelrat
    steelrat
    Post by steelrat Mon Dec 15, 2014 9:03 am
    Thanks for all the advice everyone. I will try the suggestions next time I am in the van.
    Shaun
    Post by dan nachel Mon Dec 15, 2014 5:48 pm
    To clarify....61-64 have the heater on the floor and the knob turns....65-67 have the heater under the dash and the valve is operated by cable that pulls out.
    falcondude
    falcondude
    Number of posts : 28
    Registration date : 2014-12-23
    Post by falcondude Wed Dec 24, 2014 12:17 am
    I have heat coming out all the time even with it turn off
    Abitibi
    Abitibi
    Number of posts : 479
    Post by Abitibi Wed Dec 24, 2014 11:40 am
    falcondude wrote:I have heat coming out all the time even with it turn off
    So yours is probably jammed in the open position...
    Post by Twinpilot001 Wed Dec 24, 2014 11:42 am
    off / on =Valve bad or heater cable to it bad or valves -Missing altogether?? affraid
    falcondude
    falcondude
    Post by falcondude Wed Dec 24, 2014 12:53 pm
    I will check it out, cause sometimes it gets really hot I need to seal the dog house better, it's a 302, it was changed by someone, it's my daily driver, thanks
    falcondude
    falcondude
    Post by falcondude Sun Mar 01, 2015 11:16 pm
    Does anyone have a pic so I can see where to hook it back on, I see the line is off just hanging, I want to put itback on, I put vice grips on the hose to stop the heat coming out, it help a little but it pop off while at a red light, I look in my book but shows no pic of it, just tells you what to do, wish I had a pic of it to see what it looks like to hook it back on, any help
      Current date/time is Sun May 19, 2024 7:36 am
