I want to get the front brake drum off my A100 pickup. I tried to press the studs out, as I want to change them to RH thread. I have a 20 ton press and they don't even budge. Of course the drum won't come off either. I used PB Blaster along with the press and no luck. Anyone have any suggestions?
67Dodger
docmcg
Front brake drum
docmcg- Number of posts : 205
Registration date : 2014-09-08
Front brake drum
67Dodger- Number of posts : 78
Registration date : 2013-02-10
Re: Front brake drum
Do you mean to say that even after you take the wheel bearing off, the drum will not come off? Have you adjusted the brakes away from the drum as far as possible? Does the drum turn, but not slide off of the spindle?
Well.....IF,,,, you got the hub off the spindle,,,,,,AND,,,you want to get the drum off the hub,,,,,,the studs are staked to the drum,,,,,pushing a stud out of a DRUM, will probably break the hub or at least strip out the serrations in it,,,,,,you need to make the studs skinnier to release the drum and let them slide out the hub,,,,,and the drum is probably rusted solidly to the hub ,,,,,,I like to soak the the hub with penetrating oil,,,,put some pressure down on the hub,,,,tap on the studs and hope that the hub and studs drop down,,,,,,a hole saw is the real tool to remove the flange and a torch to heat things up helps......
https://vintage-vans.forumotion.com/t16376-help-looking-for-a-front-hub-and-drum-right-side
I had the hub and drum off together. Found out that a bigger hammer always gets it done. As a side note, I want to change the LH studs for RH. Is there a particular part # I need to get. I went to Napa and another parts house here in town and could get close but they were alittle too much or not enough. Also, on the backing plate there's a soft washer, almost like a seal of some kind that the hub rear seal fits into. I've never seen that before. I kind of wonder if it's a critical thing. What do you think?
dodge A-108- Number of posts : 67
donivan65 wrote:Well.....IF,,,, you got the hub off the spindle,,,,,,AND,,,you want to get the drum off the hub,,,,,,the studs are staked to the drum,,,,,pushing a stud out of a DRUM, will probably break the hub or at least strip out the serrations in it,,,,,,you need to make the studs skinnier to release the drum and let them slide out the hub,,,,,and the drum is probably rusted solidly to the hub ,,,,,,I like to soak the the hub with penetrating oil,,,,put some pressure down on the hub,,,,tap on the studs and hope that the hub and studs drop down,,,,,,a hole saw is the real tool to remove the flange and a torch to heat things up helps......
I used a BFH .I just knocked the studs out of the hub and drum (after removing it from the van , of course) then a few more taps and the hub separated from the drum. I got right hand studs from oreillys and tack welded them to the back of the hub after installation. now I have new studs and nuts AND slip off drums
dominicsitalian- Number of posts : 15
Registration date : 2014-06-04
Will the front wheel cylinders come out to replace? Seems like i can only access one of the bolts, the position of the second bolt under the the brake hose is impossible to get to.... and yes I did remove the hose...lol
- Number of posts : 8729
can't say i remember any problem ? what about a off set wrench,
or remove the entire backing plate, that way you can clean everything up,
and paint it while you are that close,
