    Shift linkage bushings?
    cole63
    cole63
    Number of posts : 90
    Shift linkage bushings?  Empty Shift linkage bushings?
    Post by cole63 Tue Sep 23, 2014 10:16 am
    Needing some shift linkage bushings for a 67 van I just picked up. Been searching Mac's and Carpenter's with no luck? Anyone got a part number or a link on what I need?
    Thanks, Cole
    bobby light
    bobby light
    Number of posts : 47
    Registration date : 2014-09-13
    Shift linkage bushings?  Empty Re: Shift linkage bushings?
    Post by bobby light Wed Sep 24, 2014 6:19 am
    I am in the same boat with my 67. Just noticed my linkage is running on metal. Let me know what you find out. I may just turn some down out of delrin on my lathe.
    Post by Twinpilot001 Wed Sep 24, 2014 6:46 am
    get over to a wholesale =LARGE!! Bearing house- take the od & id with u or=? an old bushing? Ask them if they have any oilite bronze bushings?? id also add to see if someone has (speed shop-auto parts) any shifter bushings-came with most all Hurst & aftermarket floor shifters! Likely someone here will have some part #'s as this has been covered several times in the forums. Have u searched here in the "E" parts or working on forums?????????
    Carl
    Number of posts : 143
    Post by Carl Wed Sep 24, 2014 3:37 pm
    For the column shift levers, from the www.macsautoparts.com microsite "Ford Pickup 1948-79", used part # C3TZ-7343-KT -For the bushing kit where the shift rods connect to the transmission shift levers, from Macs microsite "Ford Econoline 1961-67", - used part # B9AZ-7343-KT
    cole63
    cole63
    Post by cole63 Wed Sep 24, 2014 3:54 pm
    Thanks for the help guys. Carl, that's exactly what I was looking for.
      Current date/time is Sat Apr 27, 2024 12:10 am
