    Column shift bushings
    Fairlane514
    Fairlane514
    Number of posts : 36
    Registration date : 2023-01-28
    Column shift bushings Empty Column shift bushings
    Post by Fairlane514 Tue Mar 28, 2023 8:12 am
    I have a 63 Econoline truck, is there a source for the bushings at the bottom of the column shaft? This is a manual 3 speed column shift.
    Not sure how to add a photo.....
    Number of posts : 2086
    Column shift bushings Empty Re: Column shift bushings
    Post by Seth G Tue Mar 28, 2023 5:34 pm
    They used to be but I'm not finding them in a quick search online. Might be able to find some bronze bushings at the hardware store that will work.
    Fairlane514
    Fairlane514
    Post by Fairlane514 Tue Mar 28, 2023 6:04 pm
    Ok, I will disassemble tomorrow and see what I can find
    Post by donivan65 Tue Mar 28, 2023 8:22 pm
    they talked about bushings here a while back,,,,
    https://vintage-vans.forumotion.com/t44002-shift-linkage-bushings
    Fairlane514
    Fairlane514
    Post by Fairlane514 Tue Mar 28, 2023 8:33 pm
    Thanks, I read the posts....
    The bushings I am referring to are at the bottom of the shaft from the steering column. Appears to be a grease fitting there as well. They are on the vertical long shaft that runs along side of the column.
    Post by donivan65 Wed Mar 29, 2023 3:50 pm
    Column shift bushings Dscn0249
    Column shift bushings Dscn0250
    Fairlane514
    Fairlane514
    Post by Fairlane514 Wed Mar 29, 2023 4:58 pm
    Yes, thats it. Messed with it today, the shaft tube bracket was the most worn part. Ended up making an aluminum sleeve to fit the ID. Probably going to ad as washer or valve spring shim to take up some slack on the shift levers.
      Current date/time is Sat Apr 27, 2024 3:00 am
