I have tried to locate some linkage bushings fpr my 66. I need all of them for both linkages. Does anyone have a line on replacements? Thanks!!
3 speed Manual trans shift linkage bushings ?
jkr- Number of posts : 1148
i know aftermarket door hinge pin bushings are really close in size and cheap too.
Thx, I will look into those. that's all I found when I searched the forum also. I was hoping for factory replacements but Ill prob just make some if the hinge pin bushings don't work out.
Dingeldeins- Number of posts : 20
Registration date : 2013-02-19
Didn´t You buy that blue A 100 on blocks?
Dump question: What bushings do You mean? I took apart the complete shifter and the linkages! The only bushing I can remember was on the lower end of the Shift control.
Can You post some pics?
Yes, I own the blue 66. I also have a build thread in the members forum as well. Back on topic, it is the bushings at the linkages at the transmission. There are 2.
Wheelie,I took one of the arms off and went to Lowes..you'll get bushings that are close enough,worked for me.
any bushings u need =can be bought at many wholesale bearing houses - not auto parts - theye called oylite bushings -come in many sises & u will need to take the thickness needed and the id(hole dia for rod) and the OD (where it fits into)
Twinpilot001 wrote:any bushings u need =can be bought at many wholesale bearing houses - not auto parts - theye called oylite bushings -come in many sises & u will need to take the thickness needed and the id(hole dia for rod) and the OD (where it fits into)
great info, I was needing some of these myself
