Non Column Manual Shift Linkage
Number of posts : 822
Registration date : 2010-09-10
Post by Roman on Sun Jan 16, 2011 12:47 am
Does it exist? If so, I need one.
If anyone has any expertise on adapting or fabricating shift linkage for a 5-speed manual transmission please contact me.
Number of posts : 3022
Re: Non Column Manual Shift Linkage
Post by RodStRace on Sun Jan 16, 2011 7:27 am
No experience with doing this. I can offer a few things to look at.
Consider how the shifter is currently on the one you want to use.
Dodge B vans had floor shifters with big long linkages. The shift forks were on the side.
Many FWD cars have cable setups, some have linkage. If your trans has a top shifter, cable may be the best solution.
Look at Panteras and rear engined race cars with transaxles. They often have a special input for the shifter and only one or 2 linkages. This would require the most fabrication.
There was a company at SEMA a couple years back that had a very cool transaxle with a paddle shifter that triggered solenoids to shift. Problem is, the basic setup that could hold V8 power was 20K!!! However, you could engineer a solenoid or air shifter that mounted to the trans and operate it using a stick or paddles or even steering wheel buttons.
douglas_sisk
Number of posts : 7
Registration date : 2016-04-19
Post by douglas_sisk on Sun May 15, 2016 9:21 am
Any progress on your shifting project?
If you have any updates I would love to hear about them.
I am really new to this van stuff but am running ideas through my head on what to do to mine. Power steering from a Saturn really interests me and to do that I need to get rid of the column shift as well. I am thinking right now grafting a cable linkage to the factory three speed (simple linkage on the side) to prototype it and ultimately I would love to have a 5 speed. The biggest challenge I see right now is most 5 speed boxes have the shift assembly on top.
    Current date/time is Tue Jan 23, 2018 5:59 am
