BACKSTORY
I have a 62 Falcon Clubwagon that has a 200 in it. Specifically a 68 Block paired with a 69 head. It also has a Carter YF Carb on it. Ok, those are the facts.
Long story short, I bought my van 7 years ago. Since the day I got her, she purrs like a cat when she is running. I worked on it a bit, just small fix up type stuff though as I'm trying to learn how to work on this. I've never had much knowledge in this realm, and I had always wanted an old van and thought it would be a great way to learn. Low and behold I had a series of things happen that kept me away from working on it. During the this break in time for me, all of the gas went bad in it. So I cleaned the tank and steel brake lines out. I put in new rubber brake lines where needed, replaced the fuel filter and even added as secondary inline fuel filter just as an extra precaution. I also bought a carb rebuild kit and took on the task of that. I have a friend that had the carb body and pieces "ultrasonic" cleaned I believe its called.
I get the carb back together, and have a mechanic friend be by my side for the big day. With a few tiny adjustments, she roared to life. I couldn't have been happier.
CURRENT ISSUE
This was a few weeks ago. Today I took it out, and about 20 minutes into my drive, she started bogging and stalled. It did this once earlier this week as the initial bog happened in about the same amount of time from when I left the house. The only difference was, that time I was pretty much back at my house, and it only did that bog once. I was able to get it home almost immediately after. So today, I was about 20 minutes from home when the first bog and stall hit. I let the van sit for a minute or 2 and she started right back up. Same good purr as usual. Then about 5 minutes later it bogged again and stalled. I repeated this process about every 5 minutes and limped her back to my house. The longer the amount of time I'd let her sit after she stalled, the easier time it would have starting back up. If I tried to start it right after, it was almost like she was out of gas. But if I gave it some time, it would perk right up and be ready to roll.
So when she is running, its a charm, but for some reason its doing this. I'm not that knowledgeable with this stuff, though I do have my own speculations about it. But there are always some on here that know almost everything inside and out. So I brought my issue to you guys for help. If anyone has any ideas about this. Please let me know. Thanks again y'all.
- joe
