    HEI distributor set up.
    rustyspoke66
    rustyspoke66
    Number of posts : 180
    HEI distributor set up. Empty HEI distributor set up.
    Post by rustyspoke66 Sun Sep 07, 2014 3:20 pm
    So I'm getting ready to try this HEI setup out. Has anybody else tried this. It takes the ballast resistor out of the picture. Makes for a clean install. Almost seems to cheap to be true.
    http://kmjperformance.com/small-block-dodge-plymouth-318-340-360-complete-electronic-distributor-w-coil.html?gclid=Cj0KEQjwhLCgBRCf0fPH043IlJwBEiQAf8P8UxwchrvIePoeWl0VpO-tCJ7eYs-pF06Nd5dtdX7WHnwaAjDO8P8HAQ
    HEI distributor set up. Empty Re: HEI distributor set up.
    Post by Twinpilot001 Sun Sep 07, 2014 3:30 pm
    yes i just installed same in my 65 comet / 289 . works good yet i got mine from skip whites place on ebay a little cheaper= ill also add they make a kit to replace the module in these also!! good 4 a spare!! Just always remember to disconnect the battery when charging & be sure to turn the key off !! when batterys low or dead too! cheers
    rustyspoke66
    rustyspoke66
    Post by rustyspoke66 Sun Sep 07, 2014 3:32 pm
    Great tips, I'll need to order up a spare module kit or two. Glad to get some feedback.
    rustytoolss
    rustytoolss
    Number of posts : 624
    Post by rustytoolss Mon Sep 08, 2014 11:31 am
    Yeah I did the GM HEI module install. It was in hot rod/carcraft about a year ago. Just uses a stsndard GM 4 pin module. Works great. No more ballast resistor. So you get more Ignition voltage.
      Current date/time is Thu May 02, 2024 3:52 am
