    distibutor help
    370
    370
    Number of posts : 6
    Registration date : 2014-11-17
    distibutor help Empty distibutor help
    Post by 370 Wed Dec 10, 2014 7:16 am
    does anyone happen to know the size and thread of the screws that hold down the points and condenser? the buddy I got the van from decided to do a tune up and then parked the van for 10 years. I have al new parts to put in the distributor but the screws are long gone. any help would be a great help. I just want to hear this old van run so I can get started on making it road safe.
    EcoPU
    EcoPU
    Number of posts : 104
    Registration date : 2013-08-28
    distibutor help Empty Re: distibutor help
    Post by EcoPU Wed Dec 10, 2014 7:49 am
    I yanked mine out for a HEI distributor. I'm sure someone will pop in shortly to help you out. Welcome to Vintage Vans Smile
    370
    370
    Number of posts : 6
    Post by 370 Wed Dec 10, 2014 8:20 am
    I've been around a few weeks just reading and looking at others build threads. this is the first real question I've had
    Post by Twinpilot001 Wed Dec 10, 2014 8:22 am
    Heres  just a guess?? 10/32 or 10/24-- yet =likely -could be even # 8?? im thinking fine thd due to thickness of the mounting plate!!
    370
    370
    Number of posts : 6
    Post by 370 Wed Dec 10, 2014 9:18 am
    I was hoping I wasn't going to have the pull the distributor to figure this out.  then again it might be easier to just buy every size small screw in the lengths I need and what I don't use toss in my toolbox for something else later on..   an extra $10 would sure beat pulling the distributor and retiming this thing.
    Number of posts : 798
    Registration date : 2014-10-14
    Post by GMman Wed Dec 10, 2014 9:32 am
    You got a tap and die set? Or borrow a friends set. Use the taps to find out which size fits. I'm sure that it would be a standard size not metric. Be careful when inserting the tap so you don't strip the threads out.
    Post by GMman Wed Dec 10, 2014 9:42 am
    Or go to your local hardware store and buy a few different screw sizes and see which one fits. Like twin said, it could be an 8 or 10. Should be an easy one to figure out.
    370
    370
    Number of posts : 6
    Post by 370 Wed Dec 10, 2014 9:44 am
    that's what I was afraid of using the tap to find the thread method.   that had crossed my mind..   I just posted thinking maybe somebody had done all this and maybe knew off the top of their head.   I guess I'll resort to my other methods. . thank you all for your help
    Post by GMman Wed Dec 10, 2014 9:44 am
    The screws don't cost much. Under a dollar for a hand full.
    Post by GMman Wed Dec 10, 2014 9:50 am
    Most of the time there is new screws included with the point and condenser kit.
    Carl
    Number of posts : 143
    distibutor help Empty distributor help
    Post by Carl Wed Dec 10, 2014 11:20 pm
    Have a distributor laying around from a 240 engine, so checked those screws, about .175" long, not incuding the flat head, as for the thread size; -the same as the 2 screws holding the vacuum advance unit, and the heads the same as those for the vacuum advance
      Current date/time is Wed May 01, 2024 6:03 pm
