by Old Skool Tue Apr 15, 2014 5:43 pm
FOOD FOR THOUGHT,,,,, The way you put toe into a straight front axle is to adjust the tie rod so that one the wheels are turning against each other and to not have them both driving straight and true. Either outward to each other or inward..This is against each other and NOTHING else. Its going to create drag between the two tires to each other and not translate to anything else.
When he said "drifting" at 70 plus that surely has nothing to do with one brake stopping better than another and "pulling" while stopping..... I drive all day long at 80 and only slow down when I have to and mine goes all over the place. However my whole front end is shot and I have been driving one of these since I was 15,, now at 62'ish,,, LOL,,,, From king pins to all of it,, and have done a lot of things to it EXCEPT for to take it in and really have someone who understands a straight front axle REALLY dial it in. With that, there is no point in my doing that unless I start with the new king pins, and like all the rest,,, NO TIME for mine,,,, dratzz
The caster is going to give you control or no control and if you increase the toe that may be setting the caster slightly different as its changing the angle of attack of the wheel however it would seem to me that the correct way would be to set the caster correctly. If the caster isn't correct, you may be on the edge of controlling it UNTIL you hit 70????
In order to set the "camber" in a straight front axle the axle needs to be bent. You may have different "camber" on an axle as one side may be bent or not the same as the other side? So it would be hard to get the "caster" the same on both sides if you didn't start out the same in the 1st place??
Caster is set by using angles shims in between the springs and the axle itself. The angled shims twisting the axle one way or the other which is actually tilting the king pins one way or the other.
If the truck is "drifting" IMO,, I would find a GOOD heavy duty truck suspension place and start with a REAL alignment appointment to see exactly what your front axle is set at??? A GOOD alignment shop will tell you what your actual caster angle is set at now. I am suspecting that yours is off as well as some slack in your steering box. Any bad ball joints would be obvious as well as king pins but they all also are part of it. You have a big box that gets shoved all over the road, but drifting sounds like alignment is the start.
Spring lengths are designed for ride ability by the ratio of the dimensions from the center of the spring to the front eye as well as the same to the shackle. There is a formula and a science also to that...
Just for thought ,,,
vic
