If you're cutting up that corner I need the corner under the light bezel that houses the turn signal and also connects to the center grille. The lower passenger corner with the horizontal lines. Maybe that's the same part you're needing but if not and you're looking for the upper section I'll take the lower section.Seth G wrote:I could use the passengers front corner, rail seam and windsheild edge to the bottom from mid headlight bezel to the door. I'm not far from Seattle.
I was just about to cut mine off and try to beat it back into place but I'd prefer to buy out and find a section that's already ok and weld it back on.
Let me know.
thanks
Brad
shop 714 834 9968
brad@woodsurfboardsupply.com
