by 66ThunderVan Fri Apr 04, 2014 7:16 pm
Hey Bob, if your bottle jack won't work horizontally, a screw jack, like from a mustang, will work. Like Dan said, a little at a time. You can use the same push point to push the headlight bucket and nose out as well. Just cut 2x4s to fit. Slow ,easy and light hammer and dolly. Take lots of measurements and be careful not to push too far. The bumper and door are toast, so you will need replacements. The lower panel can be pushed from below, using the axle as a push point. Some of the parts may not straighten out and the areas that show may need filler but try to keep the filler to a minimum. The foot box may need some welding after it is back in shape from what I see in the pic.
Chris
