    Gas tank sealer and my tailgate.
    Das Boot
    Das Boot
    Number of posts : 76
    Gas tank sealer and my tailgate. Empty Gas tank sealer and my tailgate.
    Post by Das Boot Tue Sep 03, 2013 3:26 pm
    So I've been stripping the paint off my tailgate expecting the worse, but it appears just to have been beat all to hell and back but not rusted. I'm in the process of fixing the damage and I got to thinking that the same gas tank sealer I used for the gas tank would work great for the tailgate. Treating and protecting the inside from rust. Am I going overboard or will it not work? Should I leave it alone? Anyone else tried this?
    Number of posts : 8732
    Gas tank sealer and my tailgate. Empty Re: Gas tank sealer and my tailgate.
    Post by dix Tue Sep 03, 2013 3:58 pm
    just my 2 cents but i'd use either a rust stop product. or a rustolium paint any thing is beter than nothing. .If you used a tank liner it should have been a 3 stage system but i 'm only guessing it would work but cost a lot of money,
    Randall711
    Randall711
    Number of posts : 63
    Registration date : 2013-07-29
    Post by Randall711 Tue Sep 03, 2013 4:59 pm
    Is there any type of access panel to get into the inside of it?
    Das Boot
    Das Boot
    Post by Das Boot Tue Sep 03, 2013 5:56 pm
    it's open to the elements. I'm not nuts about cutting it open that's why I thought a gas tank sealer system would be perfect to protect it. If they weren't rare as chicken lips I probably would worry so much with it.
    Randall711
    Randall711
    Post by Randall711 Tue Sep 03, 2013 6:42 pm
    I'd prob just take some por15 and dump it in and wiggle it around to be honest, I've never seen a tail gate on an econo so I can't give you the best advise on what exactly I would do. But if I can't get in there to clean out the inside I think I'd resort to just putting por15 inside and calling it good enough. And due to the rarity of the tailgate I would never suggest cutting it open unless it was real bad or you were going to make a new outer skin.
    Leather & Steel
    Leather & Steel
    Number of posts : 30
    Registration date : 2013-08-30
    Post by Leather & Steel Tue Sep 03, 2013 7:14 pm
    I think you would be a lot better using a rust converter product inside the gate instead of a tank liner. Tape off one end and pour some in and then tape off the other end so you can swish it around and once you have everything coated remove the tape and pour out the excess.
    Randall711
    Randall711
    Post by Randall711 Wed Sep 04, 2013 11:32 am
    I'm with L&S on this one find some por15 just be sure that if you have left over you put it in a new can and make sure the lid is clean and has no paint on the rim. Or you will never get the can cap off again lol
    Number of posts : 466
    Post by Sy Hollinshead Wed Sep 04, 2013 11:19 pm
    You need a cavity wax, which is designed specifically for treating the inside of panels and cavities that you can't get to with paint.
      Current date/time is Sun May 19, 2024 9:32 am
