has any one had their gas tank sealed w/ epoxy sealer inside the tank ??? if so how much does it cost?? and are you pleased w/the result.
gas tank sealer
- Number of posts : 8729
gas tank sealer
jkr- Number of posts : 1148
Re: gas tank sealer
the " por 15 " stuff is what i used. comes in a kit and is reasonable in cost. trying to find a tank is not an option for earlys. this stuff will seal pin holes by its self and bigger holes that are taped from the outside. follow the instructions to the letter and it does a great job. cut a corner and suffer the consequences.
www.por15.com i think.
Re: gas tank sealer
thanks dix...
kgdb- Number of posts : 266
Registration date : 2009-12-03
Re: gas tank sealer
I have lined many tanks, from motorcycle tanks to auto tanks. Red Kote or Caswell is the way to go. I would use Caswell, it is a superior epoxy liner and I have never had a failure and it is rather straight forward to do.
kgdb
kgdb
Re: gas tank sealer
This thread has info about gas tank coatings:
https://vintage-vans.forumotion.com/between-the-seats-g-f17/gas-tank-where-to-start-t10126.htm#38434
