Well, spent day on the GMC today ripping out seam sealer on roof and patching little holes and one big duck taped hole. I also patched some rocker panels. Who ever painted this darned thing just put 1/4" of bond right over rust and dirt and what ever else (bastard). Anyways what should I use for seam sealer around the roof? Are there different kinds, is one better than the others? Or is there something I could get at Home Depot that would provide a better longer lasting seal?
ndjarrett
Seam Sealer
campin'fool 2- Number of posts : 252
Registration date : 2013-02-02
Re: Seam Sealer
For roof drip-rail gutters I use 3M self leveling. It works great sets up nice and flat.
Joel
Joel
- Number of posts : 8726
Re: Seam Sealer
I agree 3m is always been a standard that every one else tries to follow. no homey depo junk.
Re: Seam Sealer
And smooth it out after you put it on. I found some on the 64 while I was messing with the wing that looks like bird$*** that I am going to have to redo.
Re: Seam Sealer
Are you guys talking about the top edge of the roof or on the side just under the drip rails? My top side is fine but but just under the drip rails looks like small beads of some kind of caulk is brittle and peeling off in places. Also, if you're prepping the top of the roof for paint and there is special stuff in the drip rails, how do you prep without messing it up?
Re: Seam Sealer
It goes under the drip rails and also at other seems.
Re: Seam Sealer
I was thinking drip-rail but after re-reading I guess the question is the lower seam.
I use 3M heavy body seam sealer on other seams. I put 1" masking tape either side of the seam, run the bead then shape it with a filler spreader. If it is an indented seam I use one of the corners of the spreader.
Joel
Joel
ndjarrett- Number of posts : 357
Re: Seam Sealer
Actually I was asking about the top of the drip rail. :-)
Re: Seam Sealer
Just to be clear on this Neal, could you post a picture of the area?
Joel
Joel
Re: Seam Sealer
OK, later this evening.
Re: Seam Sealer
if it's the rain gutter use 3m self leveling if it's under the gutter were the side walls run up to the gutter follows Joel's 3m heavy body seam filler suggestion
Re: Seam Sealer
Yup rain gutter...so I used wrong terms
Re: Seam Sealer
I think the 3M self leveling product number is 8307. Check around there may be other brands out there at a better price. I like 3M but on the other hand they don't pay me to pitch their stuff! Good luck.
Joel
Joel
- Number of posts : 12218
Re: Seam Sealer
Re: Seam Sealer
If you want to prep your roof for paint, how do you prep the rain gutters so as not to mess them up?
Re: Seam Sealer
most of the time the 40 plus year old stuff had lost it's life and has some cracks of lifting or shrinkage. so what i did was bought a heavy duty wire wheel on a 4 1/2 in grinder and removed every thing . and then replaced it with the 3m products.let it cure before painting.
Re: Seam Sealer
Exactly what dix said.
Though many of these vans have been re-painted few have been restored. The old sealer should be removed. Even if you can't see it yet, you'll end up finding rust under it at some point.
The wire wheel is the main (and cheapest) tool for this job. Other tools you'll want handy are a screwdriver (tap gently with a body hammer down the channel) and a dental pick (with the hook on the end).
Wear eye protection with all the tools above and for gods sake pack a lunch, the time the job takes FAR exceeds the entertainment value.
Joel
Joel
Re: Seam Sealer
well put Joel.
