    Recommendations for 4-post lifts
    blackace
    blackace
    Number of posts : 450
    Recommendations for 4-post lifts Empty Recommendations for 4-post lifts
    Post by blackace Wed May 08, 2013 6:21 am
    I was wondering if anyone had any recommendations on quality brands and pros and cons of a 4-post life, to be used for storage of vehicles. I now have a place for one cheers and want to get one that is good quality and not have one car on top of another.
    Some questions that I have would be:
    anyone has used the lift jacks that are an option for them.
    How do the casters work on a lift?
    do the drip pans cover entire car below?
    ??? Question
    Thanks for all that can help.
    Number of posts : 3046
    Recommendations for 4-post lifts Empty Re: Recommendations for 4-post lifts
    Post by RodStRace Wed May 08, 2013 7:41 am
    I've got one. It's one of the cheap ones and I've had no problems at all with it.
    If you can find a name brand one used, it may be a better investment. Sadly with the economy the way it is, good equipment is often available cheap.
    As for the detailed questions, that varies depending on the brand.
    Recommendations for 4-post lifts Garage
    Number of posts : 512
    Post by pan58head Fri May 10, 2013 5:54 pm
    Check out gregsmithequipment.com I bought 12,000 2 post from them pretty cheap. I use it everyday without a issue. They sell 4 post also. Bob
    blackace
    blackace
    Post by blackace Mon May 13, 2013 6:44 am
    pan58head wrote:Check out gregsmithequipment.com I bought 12,000 2 post from them pretty cheap. I use it everyday without a issue. They sell 4 post also. Bob
    I had seen that add in the Auto & RV mags that I get, just was not sure how good they were. I have read different horror stories about lifts that break or drop the top vehicle due to failure of the lift.
    I am looking for mainly storage purposes but figure can use it for when needing to work under a vehicle to make things a bit easier on this old body.
      Current date/time is Thu May 02, 2024 7:37 pm
