Can someone please verify my understanding of the time tab on this 1967 Dodge A100 225 Slant 6. I am thinking the hole is zero and the marks indicate 5 degrees. It is stamped before and after for people like me. Is this correct?
Dodger 359
Timing Tab
Dodger 359- Number of posts : 94
Timing Tab
- Number of posts : 8731
Re: Timing Tab
you got it... what does the book say the timing should be set at ?? don't forget to disconect the rubber hose going to the distributor and plug it with a bolt when setting the timing,
jkr- Number of posts : 1148
Re: Timing Tab
and those old leaning tower of power engines were real bad for the vibration dampner moving on the rubber so don't get real excited that the timing might be off a bunch with a timing lite.
Re: Timing Tab
Book specs are:
Plug Gap: .035
Dwell: 42 degrees
Point Gap: .020
Timing: 5 Degrees Before Top Dead Center
Idle (Neutral): 550 RPMs
Valve Lash: .010 Intake, .020 Exhaust (Fully warmed Engine
Hope it's correct. Gonna check mark with the ole coat hanger trick.
Plug Gap: .035
Dwell: 42 degrees
Point Gap: .020
Re: Timing Tab
One more question. Do I need to plug the distributor hose or the barb on the carb or both?
Thanks
Thanks
Re: Timing Tab
do both!
Re: Timing Tab
So long as the vacuum is interrupted/blocked from the advance, you are fine. Either pull the hose from the advance and plug the line OR disconnect the hose at the carb and plug off the port.
Re: Timing Tab
Ok, I disconnected the hose from the carb and plugged the port with a piece of hose with a bolt plugging it and left the distributor hose unblocked, hanging in the wind. Comments?
Re: Timing Tab
jkr wrote:and those old leaning tower of power engines were real bad for the vibration dampner moving on the rubber so don't get real excited that the timing might be off a bunch with a timing lite.
... is there a way to get to the "real" numbers??, i took the balancer from my old six to put on an newer engine that says 12 btdc, Dodger359 numbers is 5 btdc, i find the numbers away from each other , is there a reason for that???.....corrosive
Re: Timing Tab
My timing tab only shows 10 degrees before and after TDC. If my timing was 12 BTDC, I would have to eyeball it. I have read 0 TDC as well as 5 TDC for 225 slants. Also read of differences if you have Clean Air Packages on the motor.
Re: Timing Tab
that's where an adjustable timing lite comes into play. a small knob on the lite with a dial to show where the marks are in relation to the vehicles timing.
Re: Timing Tab
I was able to check the TDC mark with the upper most position of cylinder 1 and looks like it is close if not right on the money. Thanks for all the information.
Re: Timing Tab
always besure to adjust the points (dwell) before adjusting the timing
Re: Timing Tab
Hmmm, I do not have a dwell meter but will get one soon. What kind of symptoms would an improper dwell setting produce?
