The JB weld on my 318 timing cover let loose , I need a cover so one of the questions I had is will the 70 and later work. I can see that the older (68) has 3 mount holes on the lower left and 2 holes on the lower right while the 70 and newer has 2 lower for mounting on both sides. Ebay has a bunch of the 70 & up version for about 45.
If anyone has one they want to get rid of??? Or if you know where to get one any info would be appreciated. I checked Oreilly, napa, rockauto and autozone with no luck. I hate to buy something like this off ebay.
I was going to put off opening the engine up to inspect for a possible rebuild until next year but I guess that it is going to begin sooner than I thought. The engine was running pretty good also, a little tired but it is the original.
Thanks
Doug
Thanks
Doug
