    Synchromesh Gear Oil
    busman78
    busman78
    Number of posts : 483
    Synchromesh Gear Oil Empty Synchromesh Gear Oil
    Post by busman78 Sun Mar 31, 2013 7:14 am
    Okay I have a 67 A108, 225 Slant Six A745 3 Speed, all of 56,639 original miles, suspect when I dumped the trans oil yesterday it was the original red colored auto trans fluid, thankfully still red and no chunks of metal particles in the bottom of the drain pan. The manual calls for automatic transmission fluid or 85 gear oil,
    Has anybody out there tried the Pennzoil Synchromesh gear oil?
    Synchromesh Gear Oil Empty Re: Synchromesh Gear Oil
    Post by Twinpilot001 Sun Mar 31, 2013 7:20 am
    use only the automatic tranny oils -om assuming thats an automatic trans u have . Ill also say -if a standard 3 speed manual tranny?? u need to use an 80-90 wt. gera oil !!
    busman78
    busman78
    Post by busman78 Sun Mar 31, 2013 8:00 am
    The A745 is a 3 speed manual trans, a little beefier than the 903, seriously the original Dodge repair manual calls for auto trans fluid for the manual transmissions and 85/90 gear oil in warmer climates. So happened I ran across the Synchromesh manual trans fluid while at the auto parts shop. Specifically designed for synchromesh transmissions and safe for yellow parts (brass).
    Number of posts : 8732
    Post by dix Sun Mar 31, 2013 8:45 am
    If your staying south with the van in the winter then you can use either, synchomesh sounds like their just sucking your money off ya.
    busman78
    busman78
    Post by busman78 Sun Mar 31, 2013 11:24 am
    It was the same cost as other gear oil brands,
    Post by Guest Sun Mar 31, 2013 11:44 am
    i would go for thicker living in the south..corrosive
      Current date/time is Sun May 19, 2024 7:36 am
