Ok, not to sound to stupid but I just drained my 3 speed trany and it had gear oil of some sort in it. So I looked in the manual to see what was recommended for a 3 speed manual transmission. It seems that you can put 2 kinds of ATF or SAE 80 or 90 weight gear oil. Just wanted to see what the consensus was on what I should put back in the trany.
pittsdriver
rustyspoke66
65 A100 Gear oil or ATF?
rustyspoke66- Number of posts : 180
pittsdriver- Number of posts : 335
Registration date : 2010-08-12
Re: 65 A100 Gear oil or ATF?
I bought a new A100 in 1969. Being the hot rod senior in high school and speed shifting I blew the syncros. It had ATF in it and that's what I replaced it with. tranny worked great for the next couple of years I had it.
80 W 90 ONLY!! The traan fluid (auto( stuff is I do believe for very cold climates- only late model trannys use the auto trans stuff-
My dad put an Amsoil 75w-90 gear oil in my 65's trans after it was rebuilt.
rear end oil-= for the van!!
thats some good stuff! Id add if your gearset is a limited slip / posi unit - must use that recommended oil for those!!
rustyspoke66 wrote:Ok, not to sound to stupid but I just drained my 3 speed trany and it had gear oil of some sort in it. So I looked in the manual to see what was recommended for a 3 speed manual transmission. It seems that you can put 2 kinds of ATF or SAE 80 or 90 weight gear oil. Just wanted to see what the consensus was on what I should put back in the trany.
If you have an automatic you use ATF (automatic transmission fluid ), if you have a manual you use 90w "gear oil" (same stuff that's in the rear end). You can get it at any parts store.
From the manual: service with automatic transmisson fluid type AQ-ATF Suffix A for all temp ranges. You can use SAE 90 in warm climates.
So I guess something like the 75w-90 Amsoil might be the way to go. The temp. range in Spokane can be anywhere from below zero temps to over 100deg. We tend to have about the full extent of all seasons. Thanks for all the input and if anybody has anything to add it would be greatly appreciated.
- Number of posts : 8726
RUSTY YOU ARE CORRECT THE MANUAL DOES STATE COLD TEMPS TRANS. FLUID . WARM TEMPS 80/90 WEIGHT...
69 a 100- Number of posts : 142
Registration date : 2009-01-03
someone put atf in mine when i bought it and it burnt the bearing in the tail shaft
Thats good to know, I ended up useing gear oil but I hanent had it on the road yet.
