+4
hometeam
8 posters
    Help! not going into gear
    hometeam
    hometeam
    Number of posts : 101
    Registration date : 2013-01-21
    Help! not going into gear Empty Help! not going into gear
    Post by hometeam Tue May 21, 2013 9:36 am
    i have 1967 a108 225 slant 6.auto trans
    van has been running great - driving home from a beach run pulled into drive way went to put it in park and it was sticking not going into PARK.
    would only go into REV. put it in Nuetral and DRIVE 1st and 2nd no problem.
    had to leave for work so put it in nuetral turned engine off pulled Ebrake chalked back wheel to leave it for this morning.
    went o start this morning NOTHING. tryed putting in park NOTHING. tryed putting in Neutral Nothing. tun key and only thing that works is electrical systems.
    van was running fantastic turn the key and go - now this. ANY HELP OUT THERE.
    Number of posts : 714
    Help! not going into gear Empty Re: Help! not going into gear
    Post by Gothboy Tue May 21, 2013 10:07 am
    sounds like maybe two things are going on. One being maybe somehow the shifter or cable is jamming up, and two its not allowing the neutral safety switch to be activated allowing you to start the engine. Check the neutral safety switch. There is a small possibility IT is somehow jamming up the shifter causing both problems, otherwise it seems somehow two separate things may be happening at once.
    hometeam
    hometeam
    Post by hometeam Tue May 21, 2013 12:17 pm
    where is nuetral switch? i will look to see if cable is hanging up
    Number of posts : 3046
    Post by RodStRace Tue May 21, 2013 12:54 pm
    Type 727 neutral safety switch into bing or google images...
    or
    Help! not going into gear 224489d1137279025-neutral-safety-switch-727
    hometeam
    hometeam
    Post by hometeam Tue May 21, 2013 2:00 pm
    thanks goth-
    i will trouble shoot using your expert advice.
    i will post with results tonight or more questions tonight.
    i have learned sooo much about the van with everyones help here.
    it has been fun getting her on the road again.
    Number of posts : 8729
    Post by dix Tue May 21, 2013 2:51 pm
    Yep i agree with goth block the tires and climb under and have some one go thru the gears.there is a small amount of adjustment there...
    Number of posts : 322
    Post by Wheelie Tue May 21, 2013 4:44 pm
    Just dealt with a similiar issue on JD's van. The cable broke at the top and wouldnt let it start because it was barely into park. Try Inspecting the cable at the shifter. If yours has two cables coming out of the shifter its the one on the drivers side that is the shift cable that controls gear selection. I was able to drop the shifter out behind the dash without unhooking the cables and set up the shifter in my lap after adjusting the cable at the transmission to check function.
    hometeam
    hometeam
    Post by hometeam Tue May 21, 2013 4:48 pm
    yes cable broken at the top. How did you remove shifter from the back'
    hometeam
    hometeam
    Post by hometeam Tue May 21, 2013 4:55 pm
    shifter cable broken 67 a108 anyone know the part number and where I can get it? Any pointers on how to remove so as not to make matter worst.
    Post by Wheelie Tue May 21, 2013 5:27 pm
    Good luck on finding a cable. Sad I had to repair the existing cable which had already been repaired previously. We are still looking for a replacement for his van. I bet if you can afford some downtime you need to remove the cable and have it repaired locally. It is important that it is repaired to the correct length. To remove it you have to drop the pan and unhook the cable end from inside the transmission. To get the shifter assembly off the dash you have to remove he 4 screws on the bezel then there should be 4 more screws behind that. Then carefully drop the whole thing out of the bottom of the dash being careful not to tear up the wiring. Once thats out you can unhook the cable from there and get it fixed.
    Post by dix Tue May 21, 2013 5:33 pm
    That cable is not cheap. you can try a local and see if they can make it. a company in Detroit made mine . About 5 years ago it was around $100.00 now it's over $300.00 plus shipping. http://www.imperialservices.net/Truckpart.html
    hometeam
    hometeam
    Post by hometeam Tue May 21, 2013 6:09 pm
    was able to remove cable from shifter. was able to put car in neutral. measuring cable now has been replaced before. does anyone else have any other ideas were to get cable.
    Post by dix Tue May 21, 2013 6:20 pm
    sent you a pm.
    Post by Guest Tue May 21, 2013 6:39 pm
    This company makes universal throttle cables inside of plastic sleeves. Maybe it can be used for the shifter? They offer various types of end connectors. The most expensive is $56.49. Wouldn't hurt to look into it.
    https://www.pegasusautoracing.com/productselection.asp?Product=1270
    Post by dix Tue May 21, 2013 6:43 pm
    If you removed it from the shifter you need to be carefull with those prongs so they don't brake and the same thing down below at the tranny.
    hometeam
    hometeam
    Post by hometeam Tue May 21, 2013 7:27 pm
    was very carefull in removal from shifter assembly - the cable was replaced before I think the cable was incorrect length it dangled loose I had to secure it so it would not rest on exhaust - lots of play so cable had areas of slack that put pressure on eyelet connected to shifter and it eventually crimped up in the shifter and broke off.
    I echo the need for the correct size.
    I measured the cable installed to 8ft 6in.i think too long but I could be wrong.
    I was able to use pliers and find neutral to start so neutral safety switch is working.got it started and was able to find rev gear - drive gears but I had trouble finding park- did not want to push my luck and left it in neutral
    I left cable attached to trans until I find replacement just to be on safe side
    thanks for all the expert advise and welcome more
    Post by Gothboy Wed May 22, 2013 5:45 am
    Im definitely NOT an expert on this stuff amigo. But thenka for the undeserved compliment! Very Happy
    Im sorry to hear about the loss of your cable. Sad When you can find a new one you should have a funeral for it because they're so hard to find.
    A100 Wrench
    A100 Wrench
    Number of posts : 572
    Post by A100 Wrench Wed May 22, 2013 6:27 am
    Look up boat repair in your area.They can build new push/pull cables or repair yours.Also remember to lube the pivots in the shifter while you have it out.In my area there is a speedometer shop that makes cables.
    Scotts_A100
    Number of posts : 160
    Post by Scotts_A100 Wed May 22, 2013 9:33 am
    I saw this posted on the AACA sight in the Buy/Sell - Chrysler Products section and don't know if it will help you but it just might, he has some good pictures of the cable he has. I did talk to the guy selling it and checked out his website. I myself am buying one, along with a few other items. Hope it helpd you out too. Scott...
    Here is the link:
    http://forums.aaca.org/f194/1964-68-van-nos-t-shift-351653.html
    hometeam
    hometeam
    Help! not going into gear Empty up and running
    Post by hometeam Mon Jun 03, 2013 10:39 pm
    with help from dix ~ i am cruisin with a new shift gear cable from a saint in ohio!!!!
    JariV
    JariV
    Number of posts : 117
    Registration date : 2013-04-25
    Post by JariV Tue Jun 04, 2013 2:49 am
    Boat outboard engine steering cables are push/pull units and can easily be incorporated. I use them to operate my manual trans gears. Can be bought starting from roughly 100 inch length onwards in 20 inch intervals to at least 300 inch length.
      Current date/time is Sat Apr 27, 2024 11:53 pm
