does anyone know if anyone makes a roller cam for our L6's .... 230,250 or 292 ??? if not i was also wondering if you could use roller lifters on a flat tappet cam ? and last but not least .... since we have 1.75 rockers ... can we swap out 1.85 rocker from big blocks since the have the same stud size ?
camshafts, rocker arms and lifters
ncbkr2002- Number of posts : 140
Do NOT !! Run roller lifetrs ona flat tappett cam -never ever!! Diff Hardnesses of parts -not compatable
thanks for that info .... any ideas about the rockers ? anyone ?
Here's the guys to contact for 6 banger stuff....
http://www.cliffordperformance.net/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=CP&Category_Code=C250
ncbkr2002 wrote:does anyone know if anyone makes a roller cam for our L6's .... 230,250 or 292 ??? if not i was also wondering if you could use roller lifters on a flat tappet cam ? and last but not least .... since we have 1.75 rockers ... can we swap out 1.85 rocker from big blocks since the have the same stud size ?
The valvetrain is essentially the same as a small block chevy, I would not be surprised if they use the same part numbers for much of it such as rockers, valves, valvesrpings, etc... so I think you could run larger ratio rockers, provided you check all the clearances, such as valvespring bind/stack height, valve opening, pushrod-to-slot interference, etc. Normal hotrod engine blueprinting techniques. You may require longer pushrods, and trick roller rockers might require a taller aftermarket valve cover.
