    What is the name of this part?
    NipRing
    NipRing
    Number of posts : 336
    Registration date : 2011-08-14
    What is the name of this part? Empty What is the name of this part?
    Post by NipRing Sat Mar 31, 2012 5:14 pm
    [img]What is the name of this part? 705b3f42[/img]
    Ok, my van is a 65 A/T and had the powerglide swapped out with a 700R4. The part in this picture (the cylinder with the grease fitting) is tight on the left side but very sloppy on the right (like its lost a bushing or bearing) . So even though it has tons of play I can shift fine from park into any gear no problem. But, when i go to put it back into park, that slop makes it tough. In fact I broke the bracket on the steering column from forcing the shifter too hard getting into park last fall. Whopman was kind enough to help me find a replacement. Now before I break another bracket I need to repait or replace this part pictured. What is it or where can i find one.
    Thanks guys!
    **EDIT** AH, the right side of the pic got cut off. Hope its still clear what part this is.
    What is the name of this part? Empty Re: What is the name of this part?
    Post by Twinpilot001 Sat Mar 31, 2012 5:30 pm
    shifter cross shaft
    Post by donivan65 Sat Mar 31, 2012 5:33 pm
    What is the name of this part? Contro10
    NipRing
    NipRing
    Post by NipRing Sat Mar 31, 2012 5:59 pm
    i must be missing that "anti-rattle O ring" cause it rattles a lot. Know where might i find one? Or a suitable replacement?
    thank you!
    Post by donivan65 Sat Mar 31, 2012 6:00 pm
    ,,,,,,,and just in case your local parts store is out of those bushings,,,,,,go to Home Depot and make a bushing out of PVC fittings or pipe,,,,,or slip a piece of garden hose over the ball,,,,,,,,,
    What is the name of this part? Repai231
    Number of posts : 1279
    Post by Space Truckin Sat Mar 31, 2012 6:10 pm
    U r the man Donivan !!!
    NipRing
    NipRing
    Post by NipRing Sat Mar 31, 2012 6:16 pm
    I swear Donivan, when you come to chicago in May, I'm driving down and I'm gonna buy you a steak as big as your head!! You're like Chevy Van National Treasure!
    Thank You!
    Post by donivan65 Sat Mar 31, 2012 7:03 pm
    I surely go to Chicago to fill up on Chicago Hot Dogs, Italian Beef, Sausage, Polish, Veal Cutlet and Minced Ham sandwiches,,and between meals go visit my family,,,,,,there might not even be a bushing in the cross shaft and the metal is worn out,,,,,so all the more reason to invent something,,,,,
    Number of posts : 890
    Post by jrinaman Sat Mar 31, 2012 7:59 pm
    mine was bad too. i got a nylon bushing that fit loosely in shaft and ran a bolt threw it.
    NipRing
    NipRing
    Post by NipRing Sun Apr 01, 2012 12:06 pm
    donivan65 wrote:What is the name of this part? Contro10
    So the stud that is attached to the engine bracket, is it supposed to be removable? On the back side if the bracket it appears to have been welded and now that weld is kinda broke (not spinning in place broke but at the far end of the stud it has about 1/4" of travel. Should it be removable (threaded maybe)? I'm gonna run over to my brothers house and get him to re-weld it.
    Post by donivan65 Sun Apr 01, 2012 12:29 pm
    That ball bracket is 1 piece and the weld often breaks,,,,,especially if it is used for the clutch fork cross shaft,,,,I have just put a nut and bolt with a bunch of flat washers to replace the ball when it has broken off,,,,,,
    NipRing
    NipRing
    Post by NipRing Sun Apr 01, 2012 1:45 pm
    Yeah, the weld would'nt hold. Gonna go get a stainless bolt.
    Post by donivan65 Sun Apr 01, 2012 5:33 pm
    A carriage bolt will work if you don't have enough clearance,,,,there normally won't be much stress on that ball from the shift rod,,,,,,however if the left motor mount was loose or broke, that would bend the ball,,,,,,
    What is the name of this part? Repai232
    NipRing
    NipRing
    Post by NipRing Sun Apr 01, 2012 6:59 pm
    So i bought a 2-1/2" SS bolt, two SS jamb nuts and some 5/8" hose. Put it together and cut off the excess bolt thread.
    What is the name of this part? 47c682c9
    What is the name of this part? 4b42e785
    Its much better but i still feel the linkage needs some slight adjusting. When i put it in park it just needs that tiny bit to make it go in. I put a slight bit of pressure on the shift arm to put in in park. Where as before i darn near had to slam it in. I think "Rod D" needs to be just 1/4" shorter.
    Post by donivan65 Sun Apr 01, 2012 7:38 pm
    so,,,,,,I guess your local parts store was ,,,,,out,,,,,,,,of bushings,,,,,
    NipRing
    NipRing
    Post by NipRing Sun Apr 01, 2012 7:45 pm
    donivan65 wrote:so,,,,,,I guess your local parts store was ,,,,,out,,,,,,,,of bushings,,,,,
    When i goto my local parts store and ask for anything for this van i'm usually met with blank stares and indifference. So i didnt even ask them, i just went next store to Ace. This should last a while.
      Current date/time is Tue May 07, 2024 8:24 pm
