    Motor swap in Econoline?
    Motor swap in Econoline? Empty Motor swap in Econoline?
    Post by Guest Wed Dec 10, 2008 2:51 pm
    Hello
    My question is , will a 250ci motor out of a 1973 mustang work in a 1964 Econoline that has a 170ci now? Dont know if these motors are like the 240\300 motors or are they like the 144-170-200? Thanks for any help. Glenn
    Number of posts : 987
    Motor swap in Econoline? Empty Re: Motor swap in Econoline?
    Post by RipVanArkie Wed Dec 10, 2008 4:34 pm
    Hello Glenn, the 64 has the short doghouse and you run into the same problems as you would if you were swapping in a 240/300. Also, you will need an engine xmember from a later Econoline as well. If you can find a 65-67 Econoline for parts, you're in business.
    Later,
    Rip
    Post by Guest Thu Dec 11, 2008 3:59 am
    Didn't know Ford made a 250 engine. Learn something new everyday.
      Current date/time is Thu May 02, 2024 4:36 am
