A good friend (and a great mechanic) called me saturday, he's found a 92 Ford Ranger, with an OD automatic transmission, good 2.3 motor with the exception of dropped valve. The head is off the car, the cylinder walls look good, I can get a good head from another car that is fine for about $75.00. So, for about $300 and a tune up I can put the motor in my Econo. I will have an automatic transmission, late model running gear with Fuel Injection, with the prospects of 25 mpg.
If my memory is correct, the horsepower rating is actually higher on the 2.3 than the stock 170. I drove a 2000 Ranger with the manual transmission behind the same motor for a while a few years back. I had no problem with the power, even running the air conditioner or towing a light trailer.
Anybody done this swap? Anybody see any problems from trying to pull this swap off?
Thanks
Rob
Thanks
Rob
