    Parking lights
    VanninBlaino
    VanninBlaino
    Number of posts : 361
    Parking lights Empty Parking lights
    Post by VanninBlaino Tue Nov 22, 2011 7:13 pm
    I know I read an article on here somewhere for the Chevys to have the parking lights and headlights on at the same time. Is it the same for Dodges, or is it possible? Also, will i still be able to only have my parking lights on? I cant find the Chevy link anymore, so if someone could post that or a diagram or something, that'd be awesome.
    Parking lights Empty Re: Parking lights
    Post by Vanish Tue Nov 22, 2011 7:14 pm
    Post by donivan65 Tue Nov 22, 2011 7:34 pm
    I would say the parking light wire coming from your front lights that connects to your headlight switch could be dark green,,,,,,and the tail light wire is Brown,,,so hook the parking lights to the tail lights with a jumper or a patch cord,,,,,the Chevys have a empty tail light slot so I unplug the parking light wire and stick it on the tail light terminal,,,,,I would imagine that newer versions of the switch has the extra slot or circuit to put those front lights on with the headlights,,,,,but jump those 2 wires together and see if this plan works for you,,,,,
    VanninBlaino
    VanninBlaino
    Post by VanninBlaino Tue Nov 22, 2011 7:48 pm
    Alright. Where do all these hook up at? Under the dash drivers side somewhere? I'll try to trace the wires in the morning. I hate having a bulky heater under the dash sometimes, blocks everything.
    Post by donivan65 Tue Nov 22, 2011 9:12 pm
    That would be the connector on the headlight switch,,,you need to take it out,,,,see if you see a P for the parking lights and a R for the tail lights stamped on the switch,,,,,and the switch will probably come out like this,,,,
    https://vintage-vans.forumotion.com/t25436-64-econoline-electrical-help
    Post by Guest Wed Nov 23, 2011 5:27 am
    The Dodges (at least my '64) dont have a different terminal on the headlight switch that you can connect the wire for the front park lights to. What you need to do is solder a wire from the rear park light terminal to the front park light terminal on the switch itself so they are both powered through the rear park light circuit when the headlights are on. You need to be sure to solder the wire as low as possible so the connector can still be pushed on the switch all the way. I am going to do this to mine eventually.
    And yes, donivan is right, the switch will come out of the dash just like the econoline link he posted up. Same basic principle anyway.
    Post by donivan65 Wed Nov 23, 2011 10:08 am
    I'm thinking they made a law that you need front driving lights around 1967,,,,,so maybe a headlight switch from 67-70 would be set up already for it,,,,,
      Current date/time is Sun May 12, 2024 7:50 am
