Vanner63
    Maiden Voyage
    Maiden Voyage Empty Maiden Voyage
    Post by Guest Sun Jul 10, 2011 1:50 pm
    Yesterday I was able to make the maiden voyage outside of the neighborhood streets with my 61 pickup. About a 60 mile round trip with some stop and go but mostly open country roads. Truck went down the road pretty well with new tread and was a consistent 50-55 mph. It was 85 yesterday and I dont know if the truck did not like the heat or what. After about 30 miles I started to have to go through some stop signs and the truck would not stay idilng coming to the signs. I was two footing it and kept it running, and when it would die it would start right back up. Any tips on what to look at would be awesome. The truck has a 200ci 6 in it.
    The feeling of driving this thing down the road was just cool as hell. I probably had a smile on my face the entire way! Need to work out some small things...but what fun would be if everything was perfect?
    Maiden Voyage Empty Re: Maiden Voyage
    Post by Twinpilot001 Sun Jul 10, 2011 4:29 pm
    carb?? float level too high?? vacumn leak? vacumn hose off due to backfire?/
    Post by Guest Sun Jul 10, 2011 5:30 pm
    Vacuum leak was my first thought. I noticed the PCV vent front the valve cover to the carb kept popping out of the VC.
    Post by Guest Sun Jul 10, 2011 7:26 pm
    Mine seems to be doing the same thing. Seemed to be overheating slightly, runs just fine when its running at normal temps. It was a hot day here.
    Vanner63
    Vanner63
    Number of posts : 235
    Post by Vanner63 Fri Sep 09, 2011 6:42 pm
    I remember the first time I drove my pickup after working on it all winter. Most folks would have said the look on my face at 55 mph was that of a man who had just seen a ghost. That damned truck was all over the place. Like trying to herd cats. I have adjusted the steering box and got an alignment and now I can safely go up to 70 mph believe it or not.
    Number of posts : 1383
    Post by chester42 Fri Sep 09, 2011 7:06 pm
    That first legal trip with an early has to rate right up there with sex! Very Happy
    Post by Guest Fri Sep 09, 2011 7:13 pm
    chester42 wrote:That first legal trip with an early has to rate right up there with sex! Very Happy
    word
    Number of posts : 2067
    Post by sasktrini Mon Sep 12, 2011 4:39 pm
    word
    Well there's a lot of rolling from side to side, bouncing up and down, the feeling like if you lean too far forward, you are gonna kiss the ground... I can see where you are coming from!
    But if you consider the fumes coming in to the cab, the questionable brakes that might raise the need for you to change your underwear, and the potential for motion sickness, I'd say sex is much better!
    That said, sometimes you just need to be with your early... no companion can top it! The way it thanks you for a job well done... "nice tune-up... nice brakes... nice suspension bushings... nice bodywork... nice interior... You know what? Because you are such an awesome owner that cares about me, I'm gonna be the coolest ride in town for miles!" (and won't interrupt you during the football game).
    I digress!!!
    Post by EconoCarl Mon Sep 12, 2011 4:47 pm
    sasktrini wrote:
    word
    I digress!!!
    word!
    Maiden Voyage Empty Earlys & sex????
    Post by Twinpilot001 Mon Sep 12, 2011 4:56 pm
    Honestly = speaking from some experince- The guys our age that are commenting on their 1st ride in The earlys - I do believe = the ride IS MORE Enjoyable, Lasts as long as we want and Makes us smile much longer than sex!! Happy Vannin!!!! cheers [i]
    Post by chester42 Mon Sep 12, 2011 5:06 pm
    AMEN to that Twinpilot
    delraydoug
    delraydoug
    Number of posts : 210
    Maiden Voyage Empty do a vaccum test
    Post by delraydoug Sat Sep 17, 2011 7:30 am
    hook up a vaccum gauge to port on your intake make sure your getting at least 15 lbs. of presure. rotate distributor to get maxium vac pres. check the dwell on points then dial in the carb
    Number of posts : 437
    Registration date : 2010-12-14
    Post by StuNami Sat Sep 17, 2011 8:37 am
    Maybe even the second trip too, and the third, and the....
    Post by Guest Sat Sep 17, 2011 11:11 am
    I agree, they are all a blast.
      Current date/time is Sun May 12, 2024 1:29 am
