+29
Stoopid john
Henrik
VanninBlaino
Blacklabel
Vanadian
Bear
pittsdriver
kick_the_reverb
white-lightning
kykayaker37
33 posters
Rod's AZ A-108
- Post n°91
Re: Rod's AZ A-108
Thanks, Austin. I did pull most of it out by hand. Next step is to pull an extra out of storage and then attack this one with a hammer and some plywood. I'll tap it from behind on the front edge using the plywood to reach in there and tapping with a hammer. I should be able to get it pretty darn close, using the straight one to gauge the progress.
- Post n°92
Re: Rod's AZ A-108
I sent a friend a picture from the show.
He asked for a before and after, so here it is!
Big W- Number of posts : 3282
- Post n°93
Re: Rod's AZ A-108
Very nice transformation there Rod. Great idea on the paint scheme.
- Post n°94
Re: Rod's AZ A-108
Big W wrote:...Great idea on the paint scheme.
I'll bet lil 'ol ladies find it offensive.
wylee- Number of posts : 917
- Post n°95
Re: Rod's AZ A-108
sweet..........................
- Post n°96
Re: Rod's AZ A-108
dont think we have any "little old Ladies" here as members??
- Post n°97
Re: Rod's AZ A-108
Had more smiles today when I drove it around. Even had a guy at the post office come over and talk for a while.
Got the spoiler installed today.
- Number of posts : 8729
- Post n°98
Re: Rod's AZ A-108
looking good Rod...
- Post n°99
Re: Rod's AZ A-108
Going to a local show Saturday. If anyone is nearby, you are welcome to come. It's a Mopar show at York Dodge Jeep in Prescott.
http://www.moparsonthemountain.com/
- Post n°100
Re: Rod's AZ A-108
I got second place in the Truck/Jeep class and best dressed to fit the era of the vehicle! Hope to get some pics soon, I didn't bring a camera.
- Post n°101
Re: Rod's AZ A-108
So I finally had some free time when it wasn't blazing hot. I decided to freshen up the engine area on the 108.
It needed cleaning, some stuff fixed and the wiring is scary!
So here's the start... Good thing I didn't have to open this at the shows!!!
Passenger side
Driver side
After scraping and brushing with some engine cleaner, it's a bit better.
Manifolds off, more crud
Cleand and some paint - went with Hemi orange...
Here's a tip, use aluminum foil to mask off stuff you don't want painted but don't remove.
About this point, you are wondering why I didn't prep and paint the valve cover. It was so I could do all this without taping off the top of the engine.
I had this waiting for me to get going!
Parts cleaned up a bit and installed. I didn't do a super job, just knocked of most of it and wiped stuff down.
One of the things I wanted to fix was the fuel line and long hose.
Here's the old and new, with a bender.
A few bends and some adjusting, and it's much better. Too bad it's still short. I'll figure that out when the new manifolds/carb are in place. NO foot long hose!!
Passenger side
Driver side
- Post n°102
Re: Rod's AZ A-108
I still have to prep the manifolds/carb, and drill out a broken stud, swap out the thermostat and prep and paint all the black stuff, then install it all. Gotta fix up the wiring and paint the back and bottom too, but progres has been made!
- Post n°103
Re: Rod's AZ A-108
That's coming along nicely Rod. Chrome valve cover looks sharp.
- Post n°104
Re: Rod's AZ A-108
Very nice. Going to be touching up my engine while I replace my timing and pan gaskets here soon.
Henrik- Number of posts : 156
- Post n°105
Re: Rod's AZ A-108
nice lookin' van , killer graphics! Great formation in the engine bay!
- Post n°106
Re: Rod's AZ A-108
very cool................
- Post n°107
Re: Rod's AZ A-108
Nice choice with the plain chrome valve cover man. Everythings looking killer from what I can see!
-GothY-
-GothY-
- Post n°108
Re: Rod's AZ A-108
Nice engine chores / detailing / upgrading!
- Post n°109
Re: Rod's AZ A-108
Okay, so I didn't want to just clean and paint the manifolds. It had a broken stud and exhaust leak, and you can't really paint them nice in place.
So, here's some more of the story. I also had a 2 bbl assembly I was planning on mounting, but after finally looking at them both, it would be a lot of fussing to get it working right. The 108 is linkage and the throttle is along the van's center. The 2 bbl is cable and the throttle is along the front axle.
ONE BARREL
TWO BARREL
SPECIAL WASHERS AND NUTS (some missing)
ONE BARREL separated after 3 days of soaking the bolts.
If you have a lack of power and fuel boiling, make sure to check the heat riser valve. It diverts exhaust to the bottom of the intake when cold and SHOULD flap open to keep the heat from the intake when warm. Yes, mine was stuck!
This is looking down from the intake's opening, note the flapper arm position here. You can also see another broken bolt! Darn! I must do the one in the head, but may have a machine shop do this one.
COLD POSITION
HOT POSITION
ONE BARREL
TWO BARREL
COLD POSITION
HOT POSITION
- Post n°110
Re: Rod's AZ A-108
I love the direction you have gone with your van !!!! Bill
- Post n°111
Re: Rod's AZ A-108
Spent last evening and this morning on the carb and parts.
These are before disassembly. It looks a lot cleaner in the pics!
Dipping the washers, nuts and other parts.
Evaporust is GOOD!
Always lay out the parts in order! I could probably do this carb blindfolded, but it's just smart to keep things tidy.
The metering plate, float bowl and triagle top cover have all been soaked then wiped down in carb dip.
Also note the clip puller at the right (may not show here).
One of the most useful tools when doing carbs!
Here the bolts and main body are cleaned. Still have to put the choke pull-off in the evaporust. You can't put anything with rubber or plastic in the dip.
I'll post pics of the finished evaporust parts tomorrow.
Evaporust is GOOD!
Stoopid john- Number of posts : 265
- Post n°112
Re: Rod's AZ A-108
Is that fuel bowl that out of shape or is it just the picture? If it is i can send you my old carb.
Engine looks great! What intake gasket are you going to use?
- Post n°113
Re: Rod's AZ A-108
The bowl is kinda warped, but I think it's just the way it's cast. I think they did them that way to prevent over-tightening. Thanks for the offer though!
Still soaking the rusty stuff. I got the special washers out and they look a lot better. I need to find the others I grabbed in the JY a while back. I've got stuff tucked away all over the place.
I may fix the dajiban today. It needs the fuel pump module replaced. It was darn hot yesterday, and it's shaping up to do it again today.
I soaked the triangle top part in evaporust, hoping it would come out nicer. It looks the same, so I won't bother with the main body and bowl.
Carb kit is supposed to be here Tuesday, so I'll just keep at the small stuff until then.
- Post n°114
Re: Rod's AZ A-108
I took my carb off the shelf and the bowl is almost flat.
I think it was 82* at 7am here. Crazy
- Post n°115
Re: Rod's AZ A-108
On that carb bowl it looks like someone used multiple gaskets to seal a eak and just tigtened it to wtf specs.
Ive never seen one that badly shaped. -GothY-
