All electrical stuff works, runs and drives, doors are mostly working now, needs lots of adjusting.
A brake adjust, valve adjust, trans adjust.
Runs warm, so I'll change the thermostat.
It's got a cheezy flex fan and the shroud is off. Will fix those.
Need to install the rear exhaust hanger.
Need to install roof vent, clean it inside and out.
Will make curtains for behind the seats and side/rear door windows.
Change speedo gear so it's more accurate with the tall tires.
Locks for doors.
Fix the tool compartment on the side.
