It needed cleaning, some stuff fixed and the wiring is scary!
So here's the start... Good thing I didn't have to open this at the shows!!!
Passenger side
Driver side
After scraping and brushing with some engine cleaner, it's a bit better.
Manifolds off, more crud
Cleand and some paint - went with Hemi orange...
Here's a tip, use aluminum foil to mask off stuff you don't want painted but don't remove.
About this point, you are wondering why I didn't prep and paint the valve cover. It was so I could do all this without taping off the top of the engine.
I had this waiting for me to get going!
Parts cleaned up a bit and installed. I didn't do a super job, just knocked of most of it and wiped stuff down.
One of the things I wanted to fix was the fuel line and long hose.
Here's the old and new, with a bender.
A few bends and some adjusting, and it's much better. Too bad it's still short. I'll figure that out when the new manifolds/carb are in place. NO foot long hose!!
