    Tune Up Specifications for stock I230...
    ChevyVanMan1
    Number of posts : 425
    Tune Up Specifications for stock I230... Empty Tune Up Specifications for stock I230...
    Post by ChevyVanMan1 Sat Feb 19, 2011 1:26 pm
    I have a stock 230 in my early with points and plugs. Am searching thru this site with the usual keywords and can't find tune-up specs. Also my Chevy Van Shop Manual offers no number either. Odd really. And, most of my repair books only have HEI and abover specs. Can anybody post the standard specs for tune up?
    Much obliged if you'd send, Dwell, Pt. Gap, Spark Gap, Timing Advance, Aux. Air Gap and standard turns for idle and mixture.
    Much obliged, Mark
    Tune Up Specifications for stock I230... Empty Re: Tune Up Specifications for stock I230...
    Post by donivan65 Sat Feb 19, 2011 1:33 pm
    Tune Up Specifications for stock I230... Tune_u10
    ChevyVanMan1
    Post by ChevyVanMan1 Sun Feb 20, 2011 8:37 am
    You made my day. Thanks. I have a beater shop manual, I think the prior owner tore out most of the really important pages. Might have a newer one coming soon via FleaBay.
    Thanks again, I really really appreciate the the help!!!
    Post by donivan65 Sun Feb 20, 2011 11:07 am
    As for the advances,,,,,,,centrifugal is about 14 degrees,,,,,Vacuum, 10,,,,,,and the mixture screw,,,,,set the RPM,,,,like 700,,,,,,turn the mixture screw in until you lose RPM's,,,,,then start turning the mixture screw out until you get the Highest RPM's,,,,IF,,,,,the RPM's are now over 700, adjust the idle speed back down to 700 and start all over again by turning the mixture screw in,,,,,,you match the mixture to the RPM,,,,,The mixture is set right when you get to the point where if you turn that mixture screw in, the RPM's drop or if you turn the mixture out, the RPM's drop,,,,,you need to be right in the middle,,,,,,
    ChevyVanMan1
    Post by ChevyVanMan1 Mon Feb 21, 2011 9:11 am
    That's great. I really appreciate the help. Tho I'm an old piston head, I haven't done much with old school dizzy's in a long time. My old VW, fuel injected used two sets of points--what a PITA. Thanks for setting me straight.
    Thanks again, Mark
      Current date/time is Tue May 07, 2024 3:26 pm
