I got my van non running, and the alternator was disconnocted and Im not sure how to hook it back up correctly, or what wires go to it. Can someone help?
Alternator
Re: Alternator
what kind of van?? alternator??
Eagle1- Number of posts : 144
Registration date : 2010-09-18
Re: Alternator
1966G10- Number of posts : 138
Registration date : 2009-10-14
Re: Alternator
Sorry. Its a 1966 Chevy Sportvan. I just dont know what wires to connect. because there is like nothing close to where it was orgninally.
Re: Alternator
ok same as mine - do u have any plug hanging near the alt?? also u should have a 10Gague red wire near it with a ring terminal on the end- it will go to the post on rear of alt- a larger wire than the others - be sure when ur hooling the wires up to have the battery disconnected!! let me know about the plug if there or if no plug the wire colors ??
Re: Alternator
+also - there should be "B" on the back of the lat= red 10 ga wire goes there -lokw a larger stud. then=a blur or=green wire -smaller in size goes to -"F" term and then a "white??" going to the "R" terminal - these last 2 wires come from the voltage regulator (same marked terms there) so might check color codes on the regulator to what you have on the (near) alternator- as could have been changed or spliced? questions just ask
Re: Alternator
Re: Alternator
Alright. I just checked. I Have the 10 gauge red wire. and that will connect to the "B" terminal. and then i have a yellow and blue wire. What ones do those connect to . I was looking at your picture and I only see 2 terminals.?
richie61- Number of posts : 445
Re: Alternator
Re: Alternator
The 2 wires, F and 2, on the regulator go right to the R and F terminals in the alternator,,,,,,(the darker wire would of been the F wire) so you can check it with an ohmmeter, to see if it is the right wire or if the connector is missing,,,,,,,or just put some female spade terminals on the ends of the wires and plug them into the right places in the alternator. The 2 regulator wires plug into the alternator, while the bigger battery wire screws onto it.
Re: Alternator
Alright. I got it all hooked back up. and hopefully working. I was looking at some of my other wiring. And the wires that run to my Voltage regulator and the wires are so old they just broke right off. Can you buy replacement ones.?
Re: Alternator
That's just old age catching up with your van,,,,,,,The # 3 wire on the regulator just goes to one of the little screws on the horn relay and the F and 2 just go to the alternator, #4 goes to that connector by the side of the carb, so those are just simple wires with female spade terminals on them,,,,,,you can unhook those terminals out of the connectors and put new terminals on new wires to upgrade them,,,,,,Or,,,,,,,you could rip out all your wiring and install one of those big money universal wiring kits,,,,,,
