    A745 Transmission Fluid Change
    A745 Transmission Fluid Change Empty A745 Transmission Fluid Change
    Post by Guest Fri Jun 25, 2010 6:52 pm
    Hi folks. This is a pretty basic question, so bear with me. :p
    My '64 A100 has its original /6 and A745 transmission and I'd like to check the tranny fluid, but I can't seem to locate the dipstick. There appears to be only one in the engine compartment for the engine oil. My service manual isn't helpful at all. Gosh I am feeling pretty dumb atm.
    Please help! Thanks
    Number of posts : 1319
    A745 Transmission Fluid Change Empty Re: A745 Transmission Fluid Change
    Post by 67a 100 pickup Sat Jun 26, 2010 6:19 pm
    Ok.... In your service book go to the LUBRICATION section, page 5 fig 5 has a pic of the fill and drain plugs. Should hold about 3.25 pints of 80W90 gear oil. Fill it the same way you woould fill your diff.
      Current date/time is Sat Apr 27, 2024 3:02 am
